84 Z28 axle question...
Old Nov 24, 2009 | 08:49 AM
Tyroma's Avatar
Hey gang...
I have an 84 Z28. Factory 305 H.O. car..now has 355ci. Has a factory 3.73 axle and posi...posi no longer seems to be working. What is the size of the axle that this car came with? Is it a 7.5" or 8.2" or 8.5"?
Thanks!
Ty
Old Nov 24, 2009 | 08:57 AM
Tyroma's Avatar
Re: 84 Z28 axle question...
Hey...me again...further to my inquiry, anyone know where I can get a posi-rebuild kit for my carrier? Summit Racing has a kit for an open diff.
thanks
Ty
Old Nov 24, 2009 | 09:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
7.5 with 26-spline axles. You may wish to consider upgrading to an Eaton carrier and 28-spline axles. I don't believe the OE carrier (Auburn or Gov-lock) is rebuildable. The following FAQ may provide some food for thought:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Nov 24, 2009 | 09:47 AM
big gear head's Avatar
You could have the Auburn or Governor Lock. If you have the Auburn then it's trash. The Auburn can not be rebuilt. Take it out and get a new Eaton. This is a MUCH better differential than the Auburn.
If you have the Governor Lock then you probably broke the gear on the end of the governor. The governor will have to be replaced. The last one that I bought was $75, and that was a few years ago. Replacing the governor requires a special tool. When I bought mine about 10 years ago it was $130. There is no telling what it cost now.
Old Nov 24, 2009 | 10:18 AM
JamesC's Avatar
Thanks, big, I didn't think the Gov-loc was rebuildable--but the question is why would you want to!
JamesC
Old Nov 24, 2009 | 11:56 AM
It usually cost more to rebuild one that it's worth. A new Gov Lock is about $700, so if you have a stock GM truck with a damaged gear it can be worthwhile to repair it. But for a performance car it isn't worth it.
Old Nov 24, 2009 | 02:14 PM
Tyroma's Avatar
Hey Gang...
Thanks for the info, I will start looking around for an Eaton.
Ty
6speedIROC
16
Mar 15, 2023 08:33 PM
dbrochard
Oct 3, 2015 12:43 PM
scottmoyer
Sep 7, 2015 07:06 PM
dbrochard
Sep 7, 2015 09:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
