change ring and pinion? that easy?
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
looking for an easy way to keep the stock unit in the back with better gears after the t5 swap. it has 2.73's now, it is a non-posi and its really lame lol. can you just swap in a 3.73 posi ring and pinion? i don't want a new rear end, i'm keeping the stock rims and i don't want them to stick out in the back.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: change ring and pinion? that easy?
You'll need a 3 series carrier (posi). You'll also need to set up the gears for proper wear pattern which isn't something a typical backyard mechanic can do properly.
Buy the gears you want, buy the proper posi, buy a bearing installation kit. Have a driveline shop do the swap.
Engine: M54 DOHC I6
Axle/Gears: Stock
sounds like it'd be easy to just buy a 3.08 posi and throw it in there lol. what rpm does a 3.73 with a t5 turn at 60 anyways?
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
youll be happy with the 3 73s with the t-5......
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Just had some friends help me change out a 3.23 for a 3.73. Now it's time to start moving to the front of the car
Engine: M54 DOHC I6
Axle/Gears: Stock
reason i ask is because this car see's a lot of highway miles with commuting and trips (going to massachusetts next year and he goes to cali every other year) and needs to get gas mileage. last thing you want is to be turning 3k at 60.
Changing gears requires setting the pinion depth, bearing preload and backlash. You must know how to read the contact pattern so that you will know what adjustments need to be made to the pinion depth. If you are going from a 2 series gear to a 3 series then you also must change the differential. If you want a posi then you are going to have to change the differential anyway.
what rpm does your car turn at highway speeds???
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
hectre13
Aug 26, 2015 08:17 AM
