Adjust TV cable problems
Old Nov 30, 2009 | 05:17 PM
deoverton's Avatar
Car: 1992 Camaro RS
I read the article in the tech page and pushed in the metal D pulled cable blah blah. I never heard any clicks when I flipped the throttle. Well anyways I didn't think it adjusted and drove off, first gear was way to hard even just putting it into OD it slammed. Winding through gears on normal driving and it didn't kick in to overdrive until 60ish. I played with it again today the same way and never heard any clicks. Now all gears are fine, sluggish as they where before. But now on the 1-2 shift it feels like its slipping because you get a high rev as it goes into 2nd gear. Any help as always is appreciated.
Also just to confirm since I might be wrong... The D shaped thing you push is the metal tang right?
Old Nov 30, 2009 | 05:36 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Adjust TV cable problems
Were did you find the info on how to adjust it because i just replaced my tranny and it don't get 2nd gear
Old Nov 30, 2009 | 06:03 PM
deoverton's Avatar
Car: 1992 Camaro RS
Its at the home page under technical articles
Old Nov 30, 2009 | 07:40 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
You should make sure tv cable is unhooked from throttle linkage first. Then press in cable retainer ( D thing ) and push cable towards the rear of engine or tranny while depressing the retainer. Then hook the cable back up to linkage, try and pull on it only enough to hook it into linkage. Then get into car and press gas peddle all the way down to adjust your cable you should here the clicks when pressing gas peddle.
Old Nov 30, 2009 | 08:05 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Ours was done using the-" Bowtie Overdrive TV made EZ" -source.
It's working great.
Motor is a '92 350, Carb// Holley non computer controlled.
{edit}
http://www.tvmadeez.com/article/index.php
Maybe of some help.??
Old Dec 1, 2009 | 03:17 PM
deoverton's Avatar
Car: 1992 Camaro RS
Exactly what I needed guys thanks
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
db057
Sep 4, 2015 07:57 AM
