1992 Z28 possi?
Old Dec 2, 2009 | 07:02 AM
MitchellDeMoor's Avatar
Car: 1991
Transmission: 700
1992 Z28 possi?
I am rebuilding one of my '91 Rs's and I have a '92 Z28 beat to **** sitting doing nothing. So my question is does a 1992 Z28 have a possi?
Old Dec 2, 2009 | 07:17 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: 1992 Z28 possi?
if its the original rear, it is posi
Old Dec 2, 2009 | 09:53 AM
big gear head's Avatar
Re: 1992 Z28 possi?
Check for the G80 code.
Old Dec 12, 2009 | 06:54 AM
Car: 1991
Transmission: 700
Re: 1992 Z28 possi?
Thanks guys also anyone know what kind of gears it would have if it's stock? Also what is the G80 code?
Old Dec 12, 2009 | 07:16 AM
Re: 1992 Z28 possi?
G80 is the RPO code that GM used for a limited slip (posi) differential in all of their cars and trucks. I the old '60s and early '70s Chevy muscle cars the G80 code ment that you had the Eaton Posi. In the 3rd gen Camaros and Firebirds it means that you have the Auburn, Borg Warner or Governor Lock. In the trucks it means the Governor Lock. The code will be on the RPO decal, probably on the bottom of the console lid or on the back of the spare tire cover. The codes are in alphabetical order.
Old Dec 12, 2009 | 08:34 AM
Car: 1991
Transmission: 700
Re: 1992 Z28 possi?
Thanks but this car that I have has all the codes stripped off of it. There is nothing there to look at. I read somewhere on TG.ORG that the codes would be listed if I took the cover off the pumpkin? Anyways I am sure it is a possi anyways. I know how to check if it is a possi without getting the code. Also I think it should have 3.23 gears if stock right? Thanks.
Old Dec 12, 2009 | 08:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1992 Z28 possi?
All you need should be in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Dec 12, 2009 | 10:41 AM
Re: 1992 Z28 possi?
There are no codes behind the cover. If you remove the cover you can count the teeth on the ring gear and the pinion gear. Divide the number on the ring gear by the number on the pinion gear and that's your ratio. The ring gear should have 41 or 42 teeth and the pinion should have 12, 13, 14 or 15. There are other combinations too, but these are the most popular.
Old Dec 16, 2009 | 06:13 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
Re: 1992 Z28 possi?
u could also lift the rear and spin one of the wheels, if they spin the same direction its posi, if they spin in opposite direction, its not
Old Dec 16, 2009 | 06:23 PM
JamesC's Avatar
Re: 1992 Z28 possi?
Or the limited slip is worn out.
JamesC
Old Dec 16, 2009 | 08:46 PM
Re: 1992 Z28 possi?
Exactly right, it could just be worn out. There is only one way to be sure of what is in it and that is to remove the cover and look inside.
CAMAROBEAV
European Region
Apr 29, 2021 04:54 PM
db057
Apr 28, 2019 07:45 AM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
jtwoods4
Sep 3, 2015 05:39 PM
