clutch release problem
Old Dec 5, 2009 | 04:23 PM
endo666's Avatar
Car: 84 Camaro
Transmission: Stock 5 Speed
here is the back story. transmission went bad so i replaced it. in order to do that i took the hydraulic slave cylinder off of the bell housing so i could remove the bell housing and now my clutch will not release all of the way.
i purchased a Zoom Performance Products 30009 - Zoom High Performance Clutch Kit
what is going on. i would like to get this fixed asap.
Old Dec 6, 2009 | 01:24 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: clutch release problem
try bleeding your clutch hydraulics.............. if not then you might have to replace them. i had the similar issue a few days ago with a new clutch(zoom)
http://www.summitracing.com/parts/ZZZ-HP1675-1A/
i replaced the master and slave. now my clutch works mint......... i know i prolly didnt have to replace both but it took me an hours or so to do them and 20 minutes to bleed em out........ and only cost me 80.00 for both parts together
Old Dec 6, 2009 | 01:43 PM
endo666's Avatar
Car: 84 Camaro
well i bled my clutch and im still having issues.
when the car is in the air the clutch fork will move about a inch but when it is down on the ground it only moves about half an inch.
Old Dec 6, 2009 | 02:43 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
throw out bearing installed wrong on clutch fork.
Old Dec 6, 2009 | 02:52 PM
that is another possibility
ive also had a slave cylinder go bad. same situation........
Old Dec 7, 2009 | 07:48 AM
endo666's Avatar
Car: 84 Camaro
i dont think it is. are there any pictures out there of how it is supposed to look.
Frismund Snoid
Aug 27, 2015 11:08 AM
19irocz85
Aug 26, 2015 07:54 PM
neekolzun
Aug 24, 2015 04:59 PM
smooth
Aug 18, 2015 06:34 PM
