Diff fluid ?
Old Dec 5, 2009 | 08:11 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Diff fluid ?
I was wondering what is the posi additive and oil should go in an 86 T/A rear?
Thanks for any replies.
Old Dec 5, 2009 | 08:22 PM
big gear head's Avatar
Re: Diff fluid ?
If you have the 7.5 10 bolt with an Auburn then use 80W90 gear oil and 2 bottles of GM additive. If you have a 7.5 with the Governor Lock then just use 80W90 gear oil and no additive.
Old Dec 6, 2009 | 12:08 PM
steve87ta's Avatar
Engine: 461,305TB
Re: Diff fluid ?
Thanks, It is a 9 bolt with 2.73 gears and a "spin resistant diff" . The old fluid is sticky and clear so I think there was an additive in it.
Old Dec 6, 2009 | 03:03 PM
Re: Diff fluid ?
You will still need the 80W90 gear oil. I recommend using the GM additive, but others here say that the 9 bolt doesn't need it.
Old Dec 6, 2009 | 03:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Diff fluid ?
Most everyone says 1 bottle of addtive for a posi/ls
but like for my 12bolt posi/ls I was told 1-1/2-2 since its larger/hold more oil, so it needs more addtive.
I got mine cheap from fleebay at Smittys but a GM dealer should have some too.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=270431285926
Old Dec 9, 2009 | 11:46 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Re: Diff fluid ?
hi , is 80-140 too thick?...for a posi 3-23 rear end(10 bolt 7.5)
Old Dec 9, 2009 | 11:53 AM
Re: Diff fluid ?
It's not too thick, but will increase drag a little bit. The 80W140 is usually used for towing applications.
Old Dec 9, 2009 | 11:54 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Diff fluid ?
I dunno why, 80-90 is plenty and can be found anywhere cheap.
Old Dec 9, 2009 | 01:44 PM
mooch1's Avatar
Transmission: T5 WC
Re: Diff fluid ?
ok ,thanks...i think that's what is in there ...just put it in this summer...so you say it won't damage anything with the 80-140?....i can always add a little 80-90 i guess...thanks.
Old Dec 9, 2009 | 01:48 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: Diff fluid ?
I put in M1 75W-90 and it had LSD additive already in it. I can't speak to it's effectiveness though as I have an open diff.
Old Dec 9, 2009 | 02:00 PM
mooch1's Avatar
Transmission: T5 WC
Re: Diff fluid ?
ok,,i don't remember why i put the 80w140 in ...i guess i can always drain it and put in the 80w90 in the spring...i was just worried with the thicker oil it would cause damage...i have a 3-23 auburn posi and i don't want to ruin it....thanks for all your help..
Old Dec 9, 2009 | 02:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Diff fluid ?
It not gonna hurt anything but save your money next time, if real muscle cars of the 70s were fine on regular dino 80-90 and some addtive, why fall for techno hype to get you to spend 3 times as much........
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
