drums to disc
Old Dec 7, 2009 | 05:43 PM
1991 Z28's Avatar
Car: 1991 Camaro Z28
Axle/Gears: LS1 3.23
drums to disc
I currently have rear drum brakes and I just bought a disc brake rear end from a 91 camaro. What do I need to buy to make this thing working properly? I never done anything like this before. Or should I buy a fourth gen rear end (but I heard it's wider) but will the installation be the same effort as the third gen rear end? Thanks and all input will be appreciated.
Old Dec 7, 2009 | 06:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: drums to disc
what all did you get with the rear?
it will all bolt right in. You will need the brake hard lines and the flex lines if they didnt come with your rear, and parking brake cables. Ideally you want to swap out the proportioning valve under the master cylinder as well to get the brake bias closer to the proper setting.
a 4th gen rear is the same as a 3rd gen rear but its wider. They do however have better,larger, disc brakes and some have pretty good posi units. You will have to buy custom e-brake cables, or swap the entire parking brake setup over.
Old Dec 7, 2009 | 06:57 PM
1991 Z28's Avatar
Re: drums to disc
It just came with the disc and calipers. But how much wider is the fourth gen rear end? I don't want my tires to stuck out too much.
Old Dec 7, 2009 | 08:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: drums to disc
stock tires will sit flush with the oputside of the car, the rear is something like 3.8" wider overall? The lt1 and ls1 year rears are different widths. but just marginally
IMHO, if you use a 4th gen rear, use wheels with a 4th gen offset. The 3rd gen ones dont looks right.
Im sure Stephen will post his typical pics and say its looks fine...
Old Dec 7, 2009 | 08:35 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: drums to disc
Some of your questions--proportioning valve, master cylinder, e-brake cables, width, speedo gears, etc.--can be found in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
