rear end swap
Old Dec 8, 2009 | 11:07 AM
ssor's Avatar
rear end swap
hi guys!
I have a camaro rs 91 with a 10 bolts posi differential that as drum brakes. I bought a 10 bolts rear end that as disc brakes and a lock from a 88 camaro iroc. Sould I swap the posi from my diff to the other to replace the lock or this isn't something good. I think that my axles are 28 splines and the other is a 26 so will it fit? Also the 88 diff is stock, so what type of gear ratio do you think could be in it?
Thanks alot everyone!!!
Old Dec 8, 2009 | 11:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end swap
Welcome to TGO. The following FAQ may answer most of your questions. If not, ask away.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Dec 8, 2009 | 01:48 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: rear end swap
i personally wouldn't because drums are good enough for me, keep the wheels cleaner too. but the gears are pretty much the same it sounds like. you said the 88 has a locker? that wouldn't be so wise on the street but a posi can get you in trouble too as i found out in the rain today.
Old Dec 8, 2009 | 04:57 PM
big gear head's Avatar
Re: rear end swap
What do you mean by "lock"?
Old Dec 8, 2009 | 06:15 PM
ssor's Avatar
Re: rear end swap
I think that the real name is Gov-lock, it's not a posi, it only locks the two wheels at the same time. Maybe i'm wrong?
thanks!
Old Dec 8, 2009 | 08:38 PM
Re: rear end swap
Why are you wanting to swap this rear end? Is it for the brakes? If it is then just swap the brakes onto the rear end that you already have. You are swapping a stronger rear end for a weaker one.
Old Dec 8, 2009 | 09:06 PM
ssor's Avatar
Re: rear end swap
ya that is probably what i'm going to do. One reason for the swap was that the other rear was 3.42 and mine is 2.73, but i think i'm going to buy new ring and pinion for my 91 rear instead. Thanks for the reply!
Old Dec 8, 2009 | 10:47 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: rear end swap
You realize that you have to setup new gears, right? You can't just bolt them in and go. It's not for the inexperienced. At least not unless you're really determined.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
