9" options...
Old Jan 14, 2010 | 11:53 PM
  #51
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: 9" options...
there is a plate that slides on the the axle before all the other parts.
this plate holds the axles in the housing..
look at this photo.. see the gold plate.. just nexed to the studs
Old Jan 14, 2010 | 11:55 PM
  #52
weaz4200's Avatar
Car: have a 92 camaro rs...in pieces
Engine: none now...probably 383 stroker
Transmission: none yet
Axle/Gears: none
Re: 9" options...
So then id need to get and put on the LS1 backing plates first... Then the retainers... Was i supposed to get the retainer plates with my order? (just thinking out loud.)..
Correct me if im wrong, but these would be the steps....
1. Install backing plates
2. Put bearing retainer on axle first, followed by seal, bearing, retaining ring
3. Press them onto the axle shaft
4. Install axles
Sound right?
Old Jan 15, 2010 | 12:25 AM
  #53
Re: 9" options...
4. Install axles
Sound right?
think it's called Axle Retainer plate. but ya thats about right.
when i installed mine..the only thing i bolted on was the backing plates
off my car.. i cant, for the life of me, remember if they left 2 holes open for me.. i cleaned mine up Gold anodized factry.. and bolted them on..my rear end was in, under 45 min...thats with me removing my old one. have been looking for a photo of what the thing should look like before you bolt it in.
and the axles should have a hole (mine do) to get to the retainer plat bolts.
UP DATE: beer: i remember installing longer bolts to hold my backing plates on ...I think..Beer.. they go in to the back of the tube flang.. Beer,
do you have your backing plates
Old Jan 15, 2010 | 12:32 AM
  #54
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
Have a hole where? NO backing plates yet.... Need to wait a few weeks for some cash before i get LS1 brakes....Did you get your Axle Retainer plates with your rear end? I wonder if i should have received those with the housing/axles.. ill call them up tomorrow. Thanks for your help ArticWhiteZ, im probably askin simple questions, i appreciate you bearing with me and your enthusiasm to help me out... ROB.
Old Jan 15, 2010 | 12:38 AM
  #55
Re: 9" options...
i used the backing plates off my car.. Z28 rear Disk brakes.
and the bolts it had on it... nothing more to buy, 100% bolt in..
Retaining plates came with my rear end..Yes
put the housing on a creeper and slid it under the car.
lift one end up.. install shock bolt.
lift onther end up install shock bolt..
install the 2 trailing arms your half done.
Old Jan 15, 2010 | 12:47 AM
  #56
Re: 9" options...
A hole in your Axle heads.. nexed to your studs.
this hole lets you slide a socket on the the nuts holding the retaining plates on... just asking.. did not see any in your photos..
maby 35 spline dont come with them?
just makes it sorta tuff getting to the retaing Plate bolts
could get at them from the back.. maby thats it..?
ya only have to get to them when you
take the rear end apart. (Beer)
Old Jan 15, 2010 | 12:54 AM
  #57
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
BEER AY. Sounds good. I hear ya. I gotta see if I could find a Complete LS1 Conversion Kit like the one bigbrakeupgrade has, except for the rear and at a good price... Right now im thinking that ill paint the housing, temporarily reuse the stock control arms, panhard bar, brace, just to mock it up.... No shocks..... Still got quite a bit of parts i need... Thanks... Well im out for tonight... You have a good night... Enjoy the BEER!
Edit.... N my axles are 31 spline.
Old Jan 15, 2010 | 01:12 AM
  #58
Re: 9" options...
31 Spline thats what i had installed when i paid for my rear end..
parts are easy to get
Old Jan 15, 2010 | 06:19 PM
  #59
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: 9" options...
can i ask how much you paid for it???
Old Jan 15, 2010 | 06:31 PM
  #60
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
sure.. $1135 total.
Old Jan 15, 2010 | 07:19 PM
  #61
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 9" options...
looking good, if it wasnt covered already, the areas you circles in red, dont pain them. Dont paint the inside of the housing, dont paint inside of the housing ends.
for your question about if you have the correct housing ends for the ls1 discs, they look right if that helps, look just like mine, but that really doesnt mean anything. I assume you told whoever you got it from what brakes you wanted?
Old Jan 15, 2010 | 07:29 PM
  #62
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
Indeed i did, even called up Moser just to make sure that the order they received was correct... I did call them today as well just to ask about the axle retainers. They said i dont need them (at least thats how i understood it)..
Are you running LS1's on your 9", cant remember if you said what you had. Will i need those or are those something i get when i get the backing plates/brakes?
Old Jan 17, 2010 | 06:43 PM
  #63
Eric89sc's Avatar
Car: 1989 camaro
Engine: 357 procharged
Transmission: turbo 400 with Transbrake
Axle/Gears: 342 posi
Re: 9" options...
I have a couple of questions for you about your 9 inch rear your ordered. I'm thinking about putting a 9 inch of my own.
Does your rear have the same size axles or are they offset. Also is the center section straight on or is it offset? Also is the axle tubes the same size. Thanks
Old Jan 17, 2010 | 08:11 PM
  #64
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
Yes they are offset... length wise one axle is like 31 1/4 and the other 28 3/4... Just a quick measure though. I didnt order the center section, dont know what gears im putting in yet.... It should be offset, I think all 9" rears have offset centers.. Axle tubes same compared to what??? Left side to right side, or to stock rear? The tube diameter is 3".
Old Jan 17, 2010 | 08:50 PM
  #65
Eric89sc's Avatar
Car: 1989 camaro
Re: 9" options...
Is the right axle tube the same size as the left tube? What I'm trying to figure out is does the center section sit in the center of the car. You got same width as the stock rear right?
Old Jan 17, 2010 | 09:33 PM
  #66
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
yes
I assume it has to be otherwise the driveshaft would line up with the trans.. Dont take my word for it... Ill let someone else chime in on that one...
should be... 55 3/4".
Old Jan 17, 2010 | 11:42 PM
  #67
Re: 9" options...
the the 9" ford is off set..= 1 axle will be longer then the other.
every thing about this rear end is stronger then the other Chevy parts.
stand you axles nexed to ea other. and take a photo.
Old Jan 18, 2010 | 12:36 AM
  #68
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
I know its offset and the axles a different. I assume hes askin about since it is offset, how does that work, driveshaft wise? Will the driveshaft still line up with the trans... Unless im not understandin what hes getting at.
Old Jan 18, 2010 | 12:42 AM
  #69
Re: 9" options...
By moving the ring gear to one side (off setting) the yoke is in line with the tranny..
Old Jan 18, 2010 | 12:51 AM
  #70
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
Sounds good to me... Hope that answers Eric89sc's question, if thats indeed what he wanted to know.... Thanks man.
Old Jan 18, 2010 | 06:36 AM
  #71
Eric89sc's Avatar
Car: 1989 camaro
Re: 9" options...
Ya that answers my questions thanks for taking the time to do that for me.
Old Jan 18, 2010 | 08:14 PM
  #72
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 9" options...
what?
i have the ls1 rear brakes. you will need the complete setup, backing plates, rotors calipers and abutments. the backing plates need to be installed on the axles before you install the bearings on the axles.
Old Jan 18, 2010 | 09:14 PM
  #73
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
That i understand... But my question is more so along the lines of this.... Do the backing plates act like axle retainers or are those needed as well? Im assuming the plates take place of the retainers but just wanna be 100% sure...
Old Feb 12, 2010 | 01:39 AM
  #74
weaz4200's Avatar
Axle/Gears: none
Re: 9" options...
Was curious if some one could could enlighten me as to what applications each of these center sections would be used for. More so why (the way they're designed) they'd be ideal for certain applications v.s. others. (Gears ratios included)
Trac lock
Auburn
True trac
Locker
I'd appreciate it if the response could be as detailed as possible, with an example as well..... Say for instance (hypothetically speaking), my car weighs 3000 LBS, 500 HP @ 6500, 488 Ft-Lbs Torque @ 5000, 315 x 17's rear and 275 x 17's front, and a T56 trans. How would i go about choosing the ideal gear and center? What info do i need to consider (use to calculate) in order to blueprint (if you wanna call it that) what will benefit me the most. Id just like to understand (technically and on paper) how and why someone would use a certain setup depending on what the specs and mods are of their build... THanks.
okfoz
Convertibles
Feb 20, 2015 03:59 PM
Cameron@LFM
Feb 19, 2014 12:59 AM
88rsRestoration
Mar 23, 2013 01:36 PM
Chuck84TA
Jan 7, 2013 09:06 PM
mitchberry
Nov 7, 2012 09:31 PM
