Are these the correct pressure plate bolts?
Old Dec 14, 2009 | 11:29 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
For the T56 clutch with the 700107 flywheel?
http://www.summitracing.com/parts/AR...ET&prefilter=1
Old Dec 15, 2009 | 08:28 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Are these the correct pressure plate bolts?
The GM part # for the correct bolts is 10079898. When I did my swap, I found that Pace Performance was selling them. I did a search now and I found that they have been discontinued. It looks like McLeod sells the correct bolt, but it is pretty pricey. Some people just go to the hardware store and pick up grade 8's, but that would be up to you. I'm not sure about those ARP bolts though.
Old Dec 15, 2009 | 09:27 AM
Car: '91 LS6/T56/9"
Engine: LS6
Man I just read the crazy LT1 PP bolt thread at LS1 tech forums, and wow. All over this guy:
The solution without spending $60 on the McLeod bolts is Fastenal:
Part No. 20677 HCS 3/8-16 X 2 YZ9 $1.03 ea.
These are grade 9 bolts with a yield strength rating of 180,000 psi.
http://www.fastenal.com/web/products...1120677&ucst=t
What are your thoughts? Looks like the GM bolt has a shoulder on it that might be important?
Old Dec 15, 2009 | 09:33 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
The Grade 8 bolts will work. The ARP's you posted are for Trucks, not for the T56 F-body.
Old Dec 15, 2009 | 09:35 AM
Car: '91 LS6/T56/9"
Engine: LS6
Or how about these:
ARP 652-2000
Chromemoly Bolt Thread Size: 3/8"-16, 2.000" UHL
Hex Head
Black oxide Finish
170,000 PSI Yield Strength
Wrench Diameter: 3/8"
Washers Included
Set of 5.
Once again the stupid 'comes in packs of 5' BS when you need 6 bolts! These may work so what do you guys think?
Old Dec 15, 2009 | 12:58 PM
85MikeTPI's Avatar
With the ARP's, there's no guarentee that the shoulder is as long as pictured. There no need to get the ARP's for strength, there's not any requirement beyond grade 5 like the stockers, but you do want a 50% or longer shoulder to work with..
BlackphantomZ28
Apr 24, 2016 08:14 AM
mhatfield 14
Oct 24, 2015 07:48 AM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
