who knows about 700r4 trans?
Old Dec 28, 2009 | 10:06 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
Transmission: 700r4 w/huges 3000 stall
Axle/Gears: 3.73 posi
i have a 700r4 in an 89 camaro with a 305, a few weeks ago the trans decided it didnt want to shift anymore unless it was at about 6 grand, i did a fluid/ filter change, checked the tv cable, looked at the gov and it was fine. it still did it, is it shot or is there something i am overlooking
Old Dec 28, 2009 | 10:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: who knows about 700r4 trans?
Did you adjust the TV cable? You mentioned "checking it", but didn't mention adjusting it. There is no checking it, just adjusting it.
Old Dec 29, 2009 | 10:55 AM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
yea ive adjusted it but it still didnt shift, would putting in a shift kit and clean out the valve body give me the results i need
Old Dec 29, 2009 | 12:44 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
check line pressure, gov pressure and so on. if line pressure is max it will want to shift way late and really bang into gear.
Old Dec 29, 2009 | 06:38 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
how would i go about checking that cause i couldnt find any lines on the trans. it also sometimes doesnt shift out of first
Old Dec 29, 2009 | 07:58 PM
ziggy89's Avatar
Engine: 383
there should be a port on the tranny to for testing all pressures. i cant tell you exactly where its been a while since ive done any tranny work and wat i have done is limited. ive just got a basic knowldge. a hays manual might be able to tell you
BlueIroc-Z
Jun 9, 2019 03:22 AM
camaro11j
Sep 19, 2018 08:49 AM
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Aug 6, 2015 04:15 AM
