Clutch pedal
Old Dec 31, 2009 | 11:01 AM
87TPI305's Avatar
Clutch pedal
Wasup guys my clutch pedal on my 85 firebird is super soft it goes down to the floor and it is very hard to switch it into gear.....is there a way were i can adjust it so the pedal can be normal again?? thanks
Old Dec 31, 2009 | 11:15 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Clutch pedal
This may sound stupid but do you have plenty of fluid in the system ? Do you have a leak ? Does the master or slave need replacing . If you are low of fluid fill it up and pump the pedal back and forth between fully up and fully down . Don't go all the way down or up just inbetween and see how that does . Also what are your RPMS when trying to shift ?
Old Dec 31, 2009 | 08:15 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Re: Clutch pedal
Yes...your hydraulics aren't moving the clutch place enough. Fluid level is prob. low...make sure you bleed it well after you add more fluid and check if you have a leak...it's not normal for the fluid level to drop.
Old Jan 1, 2010 | 01:34 PM
87TPI305's Avatar
Re: Clutch pedal
My fluid level is good...my transmission mount was bad which caused my tranny to jump up n down everytime i shifted gears and that threw my clutch cable linkage off how can i adjust that???
Old Jan 1, 2010 | 02:22 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: Clutch pedal
fluid level on a cable/linkage setup?
Old Jan 1, 2010 | 03:20 PM
87TPI305's Avatar
Re: Clutch pedal
you know wat i mean u aint gotta be a dum**** bout it
Old Jan 1, 2010 | 03:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Clutch pedal
There is no clutch pedal adjustments
your gonna need to check n replace hydrolic parts
Old Jan 2, 2010 | 09:38 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Re: Clutch pedal
It sounds to me like you meen that the clutch fork came off the ball stud . You may need to pull the trans and maybe the bellhousing to put it back on the ball stud .
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
