T5 TRANSMISSION FOR V8 & V6 DIFFERENCES?
Old Jan 3, 2010 | 10:59 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
I am going to see a T5 this week and i was wondering how can i tell the diff between a T5 for a 8 and 6 cyl ?....i know the the T5 v6 trans has a 10 spline shaft and a v8 one has at least 27,,,ok ,,,but besides this,,,are there any other things to look out for?....and what is the diff between a non and a world class just looking at them?....thanks.
Old Jan 3, 2010 | 11:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: T5 TRANSMISSION FOR V8 & V6 DIFFERENCES?
The sticky at the top of the page may provide some useful info.
JamesC
Old Jan 3, 2010 | 02:57 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
You can get a list of part numbers here:
http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm
Print that out and take it with you. There should be a tag somewhere on the trans...
WC T5 is visually identifiable by looking at the front countershaft bearing retainer. If it is smooth it is NWC... if it has a "Dished" center, it is a WC trans.
Old Jan 3, 2010 | 08:45 PM
Drew's Avatar
Ford T5s use 10 splines, the GM V6 have 14, GM V8 have 26.
You can spot the WC vs non-WC by the front bearing cup, but if it's got a bellhousing on it, you usually can't see it. It's easier to just look at the reverse shift lever pivot bolt... It's the bolt on the drivers side of the transmission case near the top. It looks sorta like a drain plug but it's definitely NOT a drain plug. On the WC transmissions the bolt has a torx head, the NWC have a normal hex head. If the id tag is gone, don't give much for it. The tag is the only way to identify exactly what the transmission came out of. It'll be a stamped tin tag bolted under one of the tail housing bolts.
Old Jan 4, 2010 | 02:22 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
some good info
http://www.inliners.org/Jack/T5tech.html
http://www.inliners.org/Jack/t5_page.html
Old Jan 4, 2010 | 02:52 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
damn i think both of my t-5 are WC then
Old Jan 4, 2010 | 10:47 AM
mooch1's Avatar
Transmission: T5 WC
thankyou guys,,,very helpful....i will keep my eyes open...
Old Jan 5, 2010 | 10:00 AM
mooch1's Avatar
Transmission: T5 WC
i almost forgot...what's this pilot bushing i should look out for?...what is it?
Old Jan 5, 2010 | 10:19 AM
JamesC's Avatar
Check the pics in the first thread (the pilot goes into the crank):
https://www.thirdgen.org/forums/tran...y-t5-swap.html
JamesC
Old Jan 5, 2010 | 11:09 AM
mooch1's Avatar
Transmission: T5 WC
ok thankyou..you are helping me make this swap easier ...this pilot bushing is the same for most 305 or 350's?....and i can get a T5 from a 1994 camaro...would it fit my 1985 350 camaro?...thankyou in advance.....
Old Jan 5, 2010 | 04:14 PM
Drew's Avatar
You don't want a 6cyl T5. Period.
Old Jan 5, 2010 | 04:25 PM
mooch1's Avatar
Transmission: T5 WC
so what your saying a T5 from a 1994 camaro is for a v6 engine and not a v8?...The add says it's for a v8 ...doesn't mention anything about it being for a v6....didn't all manual transmisions on camaro firebirds from 93 and on have T56 transmissions?
Old Jan 5, 2010 | 05:22 PM
Drew's Avatar
On the V8, yes. The 3.4 used the T5. I've also read that the 3.8 used the T5, but I've never bothered to confirm it.
I'd pay attention to the ID tag, and decode the number before buying any T5 to verify it's what it's supposed to be. Checking the gear ratios might not be a bad idea either.
Old Jan 5, 2010 | 05:33 PM
mooch1's Avatar
Transmission: T5 WC
well this guy selling it says it's good for a V8 ...but if it cam off a V6 car then he should say so ,,,i will stay away from that one...i would of counted the splines and make sure it was for a V8 .....thanks.
Old Sep 30, 2011 | 09:01 PM
Cody's86Camaro's Avatar
Car: 1986 SC Camaro
Engine: 305/holley
Axle/Gears: 3.42 10 bolt
why cant u use a v6 t5?
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
HikoriYami
Sep 21, 2015 07:11 PM
angel2794
Sep 8, 2015 06:22 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
