Trick Shift
Old Jan 3, 2010 | 09:06 PM
89rs305-DP's Avatar
Car: 89 Camaro RS
Engine: Built 357 Vortec
Axle/Gears: 3.23 from an '87 iroc
Trick Shift
So ive been hearing about this trick shift tranny fluid by b&m and it claims to give firmer shifts. But ive also heard its made only for ford trannys. Has anyone used this?? Is there anything else you would recommend for better performance?? Additives??
Heres some links...http://www.bmracing.com/PRODUCTS/Flu...12-qt-box-ONLY
http://www.bmracing.com/PRODUCTS/Flu...12-qt-box-only
Old Jan 3, 2010 | 10:18 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
Re: Trick Shift
I've used it. Other than price and color, I don't know of any differences. I've trashed one transmission while using it and two without all chevy thm350. The B&M was blue I thought it was harder to get a good read on it for fluid wear and level. Felt like I had to keep B&M in it after using it because i didn't want to mix fluids and colors. If anyone knows any positives let me know because I have six quarts on the shelf. Can it be mixed?
Old Jan 3, 2010 | 11:27 PM
Pro Built Automatics's Avatar
Re: Trick Shift
This goes back to the day when asbestos was still used in clutches. That was back in 1977-1978, when type "F" fluid was being used. DO NOT use B&M Trick Shift, as it is Ford type "F" fluid with their additives. Stay with a good quality Dexron III, or the later Dexron VI fluid. I have talked about this many times in the past, and there are no advantages to doing this, only negatives.
Old Jan 4, 2010 | 01:52 PM
89rs305-DP's Avatar
Car: 89 Camaro RS
Re: Trick Shift
Ok thanks. Are there any good additives?
Old Jan 8, 2010 | 08:48 PM
Re: Trick Shift
Lubegard or MT-10 are ok, but in general, they are not needed. A good quality fluid and a HD transmission cooler are all that are needed in most cases.
Old Mar 3, 2010 | 02:10 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Trick Shift
Dana, or others,
What brands are recommended as being a good quality Dexron III or IV?
Old Mar 5, 2010 | 01:14 AM
Re: Trick Shift
As afr as Dexron III, Mobil, AC Delco, Chevron Dello, are the better ones. As for the synthetics, Amsoil is the best.
Old Mar 5, 2010 | 08:04 AM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: Trick Shift
Originally Posted by Pro Built Automatics
Amsoil is the best.
Is this based on your teardowns of transmissions that used it throughout there lifespan, or just amsoil marketing?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
RS Reaper
Sep 27, 2015 07:04 PM
