how do i know if i have 4th gen 10 bolt
Old Jan 10, 2010 | 01:08 PM
tjvz28's Avatar
Car: 91 Camaro Z28
I think i might have 4th gen rear in my car
Its 91z28 vin code said 3.42 posi
i go to rear axle and it has no #s on axle tube its on the bottom of carrier
The # on the bottom is 22522878
I have opened the cover its fot aubern clucth type posi
Were can i go to look up the axle code #
Old Jan 10, 2010 | 01:18 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: how do i know if i have 4th gen 10 bolt
Since the fourthgen is wider than a thirdgen, I'd suggest looking at some pictures. There are fourthgen measurements and pics in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jan 10, 2010 | 02:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you have stock 3rd gen rims and the wheels stick out from under the fenderlip, then it's a 4th gen rear (unless someone went to alot of trouble to shorten axles).
cam-mike
Aug 24, 2015 07:23 AM
Elliswon
Aug 10, 2015 12:33 PM
