Clutch selection for 305 w/ T56
Old Jan 12, 2010 | 05:47 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Hello All,
I'm getting ready to do a major overhaul to my bird this spring, part of which includes a T56 transmission. I've got the complete setup minus the clutch, which leaves me wondering. I've tried doing a search, but most people seem to be going overkill compared to what I'll need here.
I was looking at the following two clutches:
ACDELCO Part # 381291 ($322)
RAM CLUTCH Part # 88516 ($355)
Does anyone have any input, or any other suggestions in the $300-$400 or less range?
It'll have 3.73 gears, factory Lt1 flywheel, and the factory 305 short block with Trick Flow 305 heads, Comp XR258 HR-12 cam, and Edelbrock Performer RPM intake. Car is a 1987 Formula WS6 that weighs in just a bit over 3100 lbs.
Thanks a million,
-Levi
Old Jan 12, 2010 | 08:42 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Clutch selection for 305 w/ T56
Just get a stock replacement PP/clutch from your local parts store.. $200.. No reason to do more..
Old Jan 13, 2010 | 11:01 AM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
yea i agree just go with the stock replacment, thats all i use in my car and it holds up to some 1.5s 60fts
Old Jan 13, 2010 | 12:08 PM
Engine: L98/454/M20
So, something like this bad boy from autozone?
http://www.autozone.com/autozone/cat...&parentId=12-0
Seems great to me. I'm kind of new to this manual transmission thing, what do I need to look for when sourcing a used flywheel? Heat marks, etc?
Thanks,
-Levi
Old Jan 13, 2010 | 12:15 PM
Engine: L98/454/M20
Would this be an acceptable flywheel to use? Brand new, shouldn't have any issues.
http://www.napaonline.com/Search/Det...012044+3999999
Old Jan 13, 2010 | 03:43 PM
85MikeTPI's Avatar
Yup, That's the exact one I was referring to in my reply.. $200.
Heat marks are a telltale sign of abuse. A shop can also measure it (like brake rotors) to make sure it's within tolerances to resurface.
NAPA's web site doesn't let you link, but I assume it's a stock replacement LT1 flywheel which should work with your 1pc RMS block.
Old Jan 13, 2010 | 03:50 PM
Engine: L98/454/M20
Would it be worth chipping in the extra money for an aluminum flywheel, or would I notice any difference at all? I see the steel can be had for around $100 while the aluminum runs $400-$500. Any input?
-Levi
Old Jan 13, 2010 | 03:53 PM
85MikeTPI's Avatar
-Levi
IMHO, leave the alum FWs on the track and stick with steel for street/strip. I have an aluminum behind my 427 and regret it everyday I drive on the street...
Old Jan 13, 2010 | 04:33 PM
Engine: L98/454/M20
Looks like I've found a resurfaced billet flywheel and new Autozone brand clutch for $200. Guy bought them and then never used 'em. Think that'll work?
-Levi
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
topteam54
Oct 6, 2015 12:21 AM
meeklay812
Oct 1, 2015 03:46 PM
mygta87
Sep 14, 2015 10:36 PM
tonys91rs
Sep 2, 2015 07:07 PM
