Clutch pedal help
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Clutch pedal help
I have a T56 in my car with the stock third gen clutch pedals. When I took out the old master/slave cylinder setup, the plastic clip that attaches to the top of the clutch pedal that holds the master cylinder rod to the pedal broke. Now the rod slips off on occasion, of course causing the pedal to go to the floor and be inoperable. What is the piece called that I am missing and where can I get it? Thanks!
