1344 or 1310 u-joint
Old Jan 21, 2010 | 01:37 PM
8550ta's Avatar
What are the differences between these two u-joints and how do you know which one my car uses?
Old Jan 21, 2010 | 04:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1344 or 1310 u-joint
A 1344 is a conversion joint from a 3R to a 1310 yoke. You need it if you have an aluminum shaft.
Old Jan 21, 2010 | 04:22 PM
big gear head's Avatar
The stock U joint is a 3R.
Old Jan 21, 2010 | 04:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Only on a steel shaft.
Old Jan 21, 2010 | 05:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Which is what the majority of all the third gens use.
FastBroker
Jun 3, 2001 07:15 AM
FastBroker
May 23, 2001 08:00 AM
