Pressing the clutch does nothing - need help!
Old Jan 23, 2010 | 05:41 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Sup,
I have an 82 T/A with the 4-speed manual transmission with mechanical linkage.
Here's the problem. I can't get the car into gear when pressing the clutch pedal. I got under the car and checked what was going on when the pedal was being pressed. I see the pin pushing the clutch fork, but it doesn't go that far. I extended the pin out by unscrewing it. That did nothing.
My friend tells me it's either the fork is bent or the throw out bearing is bad.
If it is any of those, how hard would it be to fix it?
Any ideas?
Old Jan 23, 2010 | 08:55 PM
M G Brewer's Avatar
Car: 1988 IROC-Z
Re: Pressing the clutch does nothing - need help!
is ur slave cylinder full of fluid?
Old Jan 23, 2010 | 09:03 PM
Car: 82,83,99 T/As
Engine: 350,350,383
Pretty sure it doesn't have one. It is not hydraulic.
cross referencing threads
https://www.thirdgen.org/forums/tran...-i-adjust.html
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
