Fluid Problems
Old Jan 26, 2010 | 01:28 PM
Crawforj's Avatar
Fluid Problems
Recently replaced my 700R4s friction plates and reinstalled the transmission.
Now however it will not go into gear and is now spraying fluid out of the vent tube, I did no shift kit and didnt touch the valve body nor did I mess with the pump. Everything under the pan is in order.. I'm sure there are a ton of possibilities but any idea on what to look at first?
Also, there seems to be no fluid getting to the lines? I'm stumped since nothing was touched aside from the clutch packs.
Old Jan 30, 2010 | 11:40 AM
Crawforj's Avatar
Re: Fluid Problems
Line isnt clogged and i'm pretty sure the fluid through the vent was overfilling. However still no pressure. No one has an idea what could cause this?
bump
92camaroJoe
Jul 29, 2023 07:57 PM
someone972
Aug 30, 2015 12:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
