turbo 350 v.s. 700r4
Old Feb 4, 2010 | 12:32 AM
84-camaro-zoom's Avatar
Car: 1984 Camaro Berlinetta
Engine: currently 2.8l v6
Transmission: not sure.. its a 5spd
Axle/Gears: don't know but it will be replaced
Im wondering what one of these two is the better one ??
im going to have a 383 stroker between 400 and 500 hp i hope..small block..
dont know what cam yet and hoping for a detroit locker 3.75:1
Old Feb 4, 2010 | 12:24 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: turbo 350 v.s. 700r4
If you do a search, there is a lot good threads regarding this. Here's one for you off the bat. https://www.thirdgen.org/forums/tran...350-turbo.html If you run a 700, to handle the power, it needs to be built for it. the 350's are cheap to build for power, but lose a lot if you care about mileage. I've done two swaps now, and after driving mine for a bit, I may just leave it in there because I do like it.
Old Feb 4, 2010 | 12:27 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if its more of a daily driver, go 700r4, but be prepared to spend a few dollars
it its more of a weekend warrior, go th350 and just be ready to spend a few extra bucks on gas
Old Feb 4, 2010 | 02:23 PM
1986maro's Avatar
Car: 86 Camaro Iroc-z
Engine: Lb9 (305 TPI)
Transmission: 700r4w/ 2500 stall shift kit
Axle/Gears: quick performance ford 9 3:70
what he said^
i had my 700 built for around 800 but the guy gave me a good deal for parts and puting it together. he said for anyone other than me it wouldent have left his shop with out $1800. i have harden cluches, band, corvette servo, harden sun shell, trans go shift kit, 2300 2500 stall, and a few other things but i cant think of right now but i wanted to use my 700 for gas mileage and i have 3:73 and she would have been winding pretty high at the end of the quarter lol.
and i love how 700r4s have a little bit lower first gear too... i leave 1st, 2nd,down in about 200 feet. (spinning of corse lol)
Old Feb 4, 2010 | 02:57 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
well the 700r4 is a 4 speed overdrive. the th350 is a 3 speed. if you drive only in town the 350 will be ok. the overdrive in the 700r4 will be much better for highway but stil good in town. gearing for the 350 are Lo 2.52 - 2.75, 2nd 1.52, 3rd 1.00. the 700r4 has Lo 3.06, 2nd 1.63, 3rd 1.00, 4th 0.70. find out what would work best for you then go with it.
Old Feb 4, 2010 | 07:12 PM
wow thanks for all the great advise guys! i live in cloverdale close to langley and im going to mission race way so i will be on the high way a good 40 minutes to hour can the 350 handle that? or will it have a hard time ? i only plan to use this car to rip around in for fun and race but i might use it as a daily driver in the summer time... maybe not if the 350 can handle the high way ill go with that one if not ill do the 700r4??
Old Feb 4, 2010 | 09:55 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
the turbo 350 is more than capable of being used in a daily driver, they were for years and years before overdrives were commonly used. the deciding factor will be what you can put up with. my car is daily driven about 30-45 minutes one way on the freeway everyday, so it will hold up.
Old Feb 5, 2010 | 08:27 AM
1986maro's Avatar
yea but u want to make sure you put a tranny cooler in too, even if you dont have a stall. i got one about half the size of my rad. i should have took more pics when i put it in.
Old Feb 5, 2010 | 08:49 AM
ls six's Avatar
The 350 will survive the highway just fine but the lack of an over drive will make the motor spin quite a bit higher than the 700.
This will effect MPG and your own comfort on long highway cruises, you may love your exhaust now but an hour of cruising in the middle of the tach can get old really fast.
Another option is the 2004R, the 700 can be built to hold 4-500 HP and similar levels of torque but it's pushing it to it's limits for anything that'll rack up real street milage.
The 2004R can be built for 1000 HP or better no problem, but the aftermarket is a bit smaller than even the 700 and the price will go up noticably. You'll beed a new torque arm mount but you really dont want to keep it bolted to the trans at the level you are planning anyway.
Old Feb 5, 2010 | 09:54 AM
1986maro's Avatar
idn i guess.... i just knew i wanted to stick with my 700 for od and and a little lower first gear. the guy that built my trany (performance Transmission in norfork) said it would stand up to 900hp easy if i kept a low stall in it. idn thats what he said.
Old Jun 15, 2010 | 04:05 AM
CamaroIROC88350's Avatar
This thread has helped me in somewhat determining if I want to put a turbo 350 tranny in my IROC-Z. I've got the car up for sale now but if I ended up not being able to sell it I've found a turbo 350 for $150 that works good & I would buy it to replace my 700r4. I don't know yet but thanks for posting this thread.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
camaro11j
Sep 19, 2018 08:49 AM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
