a few curious questions
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Im about to do the t56 swap from a 700r4. The t56 im getting will have none of the bolts. Will the flexplate bolts and the tranny bellhousing to engine bolts work from the auto? Im just curious before i go out and buy all these special bolts.
Should I use royal purple synthetic fluid in the t56?
And what fluid works with the hydrualic clutch? Brake fluid?
Thanks for everything guys.
EDIT: Also is there a 700r4 removal guide anywhere? Ive searched with no luck.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: a few curious questions
you need flywheels bolts, the flexplate ones are too short.
synthetic is fine if you want it
brake fluid
brake fluid
Thirdgen89GTA
Aug 25, 2015 06:40 PM
