92 Camaro Wont Go in Reverse Or Park
Old Feb 13, 2010 | 07:16 AM
smithjddg88's Avatar
I have a automatic v-8 rs. Last night i pulled into park and it stayed in drive so i put it in neutral then tryed to put it in reverse to back up a little and there feels like there nothing there. Any idea what it could be 120,000 miles on the car.
Old Feb 13, 2010 | 08:50 AM
Drew's Avatar
Re: 92 Camaro Wont Go in Reverse Or Park
Broken/loose shifter cable (either end), broken/loose internal linkages in the transmission, etc. I'd start by visually inspecting the shifter cable.
Old Feb 13, 2010 | 09:08 AM
well just went out to look at it. the shifter moves just fine.but when in park, reverse or neutral when running its stuck in drive. still think its the shifter cable.but when the cars off park is neutral,park wont set so the car rolls. i just bought the car iv put 144.1 miles on it so im taking it to the dealership today to see if they'll fix it.
Old Feb 13, 2010 | 09:12 AM
Drew's Avatar
Try manually moving the shift lever on the side of the transmission. Can you get it into park that way? When you put the shifter into park does the car still want to roll away? Does the car drive in neutral?
Old Feb 13, 2010 | 09:21 AM
well i live at the barrack in san diego and dont have a jack to jack the car up till later when i go down to the hobby shop.when i put the shifter in park when the cars started it trys to drive away and its the same with putting it in reverse and neutral.Now when the cars not running and i put it park it rolls away.
Old Feb 13, 2010 | 09:44 AM
Drew's Avatar
So park, reverse, and neutral all act like forward gears? If the shifter is actually shifting the transmission, I'd say the transmission is lunched.
Park should engage a parking pawl that physically prevents the car from rolling, which is why I'd suspect the shifter isn't actually shifting the transmission.
Old Feb 13, 2010 | 09:48 AM
ok thanks im going to take a look under the car. i think its the shift linkage. i havent had a problem with the tranny ran great till yesterday. post back later i have to change my oil today anyways.
Old Feb 13, 2010 | 01:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need to jack the car up, you can reach the shift lever when it's on the ground.
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
hokis
Aug 9, 2015 03:57 PM
