700R4 A/T; 1-2 shift @ 22mph
Old Feb 16, 2010 | 10:38 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
well I bought a performance Tranny, suitable of being able to handle 500+ HP... Torque Converter crapped out and I ended up replacing just the torque converter even though I was advised to rebuild tranny as well... a few months after that, my tranny would not hit its first shift till 22mph, normally it would shift at 12mph, then again 22mph... also I noticed that when I was going at around 70 mph, I would be somewhere between 3500-4000 K RPM.... which led me to believe the tranny was not engaging in overdrive... all this happens while I am in OverDrive, what could cause this? Am I looking at a rebuild? Could I possibly need the valve body checked for debris? BTW I did adjust the TV Cable, I pulled into a gas station and adjusted it... the only thing I can think of is replacing the cable with an OEM GM cable, as the one I have I got at Autozone, since it was the only autoparts store that had it locally...
Old Feb 17, 2010 | 05:19 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Re: 700R4 A/T; 1-2 shift @ 22mph
Is the car going into 4th gear? You might just need a new Torque Converter Clutch Solenoid, its what controls the Torque converter locking up.
Old Feb 27, 2010 | 11:52 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
**bump** looking for more ideas...
Old Feb 28, 2010 | 04:19 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
i was having a similar problem and it may be the springs on your governor gear.
Old Mar 23, 2010 | 12:13 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
after much reading, looks like my governor is plugged with debris, what I'm guessing from my torque converter, I'll probably end up replacing it with another corvette governor as is currently installed, or might just clean it, don't know... will post once I get the work done on it...
Old Mar 23, 2010 | 12:41 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Im assuming since you didn't rebuild you at least flushed the trans,lines and radiator and replaced the filter? otherwise sounds like you have amoney pit going
Old Mar 23, 2010 | 01:28 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I would just clean the governor, if you replace it you may have to adjust springs and weights to get the shifts like you had them before. it should clean up, unless damaged. Also, take off you pan, clean the whole trans, change filter, flush out whole thing, otherwise you'll be back in same situation again (same idea as 8upaford had). I would take convertor off and take it down and have it proffesionally flushed and then do same with trans. you probably have debris all in that thing. good luck to you.
KNBlazer's Avatar
Engine: 5.1 4bbl
Yeah well the Transmission is a Mega Raptor Level 4, which only tallied about 8K miles if not less, before my converter started making a grinding noise, confirmed my diagnostic at a local shop... then I took the the car in to get it replaced, so they did all that, but I was told that a rebuild could be in the near future... they did replace the filter and I was told to come back in a month for another change, but I didn't make it that far, then smog was due, and I finally just caved in and stored it, since money was tight... but now I am budgeting to get it up and running... on the flushing the tranny I doubt that was done, otherwise I would have been told...
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
