Magnum T-56(tr-6060)
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
hello friends, NEED SOME HELP!!!
I have a Magnum T-56 from RPM transmissions, and I have 2 plugs on the driver side for the trans, electric and manual speedo set up, passenger side have the reverse light switch toward the frt...and the reverse lock-out back by the stift...
I need the male connector for the lock-out so I can wire it in to the brake lights...as I was told to hook it up that way....sound right!
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Magnum T-56(tr-6060)
Yup. You can get the pigtail connector from NAPA or Ebay.
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
