size of differential
Old Feb 18, 2010 | 10:45 AM
jcrouse90's Avatar
ok so will a 7.5 differential fit into a 7.65 housing..
Old Feb 18, 2010 | 10:53 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: size of differential
The housings are the same. For all practical purposes there is no difference between the 7.5 and 7.625, except for the gears themselves.
Old Feb 18, 2010 | 10:55 AM
jcrouse90's Avatar
ok well i have a 7.5 posi carrier i want to put in my rearend that had a 7.65 one legger.. on that 7.5 what can i run for gears?? like is there certain ones i cant fit in there? im just wanting to buy some jegs brand ring and pinion gears to get me buy
Old Feb 18, 2010 | 10:59 AM
big gear head's Avatar
7.5 and 7.6 gears are the same except for 1/8 inch outside diameter. They will interchange with no problems. Just be sure that you get the right gears for the seried of differential that you have. If you have a 2 series tehn get the thick gears. If you have a 3 series then teh standard gears will work. There are also 26 and 28 spline axles, so be sure that your axles fit the differential.
Old Feb 18, 2010 | 11:48 AM
jcrouse90's Avatar
ok well this carrier came out of a 91 camaro. and has 28 spline i think?? does that sound correct..
Old Feb 18, 2010 | 11:59 AM
Yes, '91 should have 28 spline axles.
Old Feb 18, 2010 | 12:06 PM
jcrouse90's Avatar
now heres the problem ha.. where in the heck can i find stock axles that are 28 spline... no one has any.. and i dont know how much i should pay for stock.. im to broke to buy brand new
Old Feb 18, 2010 | 12:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Advertise in TGO's classifieds. If you have other questions about the 10-bolt, try the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 18, 2010 | 12:16 PM
A new set is about $180. The '90 to '92 Camaro and Firebird axles are 28 spline.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
88CamZ
Oct 8, 2015 10:29 AM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
