A few 12 bolt questions before I finally purchase one.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Ok, so I'm pretty sure I'm going with this rear: http://www.spohn.net/shop/1982-1992-...-Complete.html
Center Section: Detroit Truetrac
Gear Ratio: 3.73
I was curious if I should go with a 30 spline, or a 33 spline? I was going to go with the 33. But I read somewhere if you break it, 30 spline is more common and parts will be easier to find?
Also, that rear is listed under 1982-1992 on Spohns site. So I'd imagine it will be the same length as my rear now? I really don't like the way 4th Gen rears look on our cars being wider.
Thanks!
Gear Ratio: 3.73
Thanks!
Car: Used to drive a camaro
Re: A few 12 bolt questions before I finally purchase one.
I bought my Strange 12bolt rear from him a few years back. You need to be aware of your rear break options and mounting plates. I had to purchase Strange's backing plates because I was told I couldn't reuse my 91 1LE / PBR plates. I went with the 33spline myself.
Car: 1988 IROC-Z
Engine: 427 SBC
This may sound dumb, but do I need "Metric - Standard length wheel studs." Or 1/2" standard length?
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
You'll want metric if going to use stock or stock replacement wheels and lugs. I'd recommend using the extended length ARP metric lugs if you ever need to run slicks and need to pass NHRA tech.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can run slicks with factory wheel studs. The 12mm studs are very similar to the older car 7/16" studs.
You "need" longer studs if you use rims with a thick center section such as Weld Draglites. The rulebook states that the stud must protrude into the hex portion of the nut at least the diameter of the stud.
This means if you have a 12mm stud, at least 12mm of the stud must extend past the surface of the rim or washer if you use a nut/washer type of nut. The factory acorn nuts don't use a washer. The stud should extend to at least the outer surface of the acorn nut.
So if you use factory length 12mm studs and try to install Weld Draglite rims, the studs will be down inside the holes of the rim. The shank nuts you need to use will still grab the stud and hold the wheel on but they will not be track legal.
When upgrading to new axles, it doesn't hurt to upgrade to 1/2" studs. Even if you still use a factory rim, the 1/2" studs will still work.
Car: 1988 IROC-Z
Engine: 427 SBC
You guys are awesome! Thank you! I am happy, my wallet is not. haha.
"street" driven car.. If you change to 1/2" studs in the rear, then
you'll have different lugs front to rear, need a different (or multi)
sized lug wrench with you all the time, different lug torque values
to remember and most cars will not need the extra strength the
1/2" studs afford.
84z96L31vortec
Aug 20, 2017 12:16 AM
Polo Z03
Sep 10, 2015 06:43 PM
hectre13
Aug 26, 2015 08:17 AM
