5spd hard to shift when cold
Car: 1986 Z28 Iroc
Hey guys,
I have a 5spd manual in my car, not sure which, it was put in there before I got it, when it had a 350 dropped in. My question is this, when the car is cold, or even just after it's warmed up, when I first start to drive, the first couple of times I shift it into 2nd it's very stiff, no grinding really, just really stiff. All other gears are nice and smooth. Any ideas? I can crawl under there and figure out which trans it is if someone lets me know what to look for.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 5spd hard to shift when cold
Hey guys,
JamesC
Car: 1986 Z28 Iroc
No clue, haven't had it two weeks yet. I know the transmission is not the one it came with, the 305 and trans were ditched by the PO, and a 350 and this 5spd were installed. Never changed the fluid in one of these manuals, is it a pain, or a fairly simple job? I'm assuming there's a drain plug and a fill plug?
)JamesC
Car: 1986 Z28 Iroc
Thanks man. This community has been invaluable for me so far, glad I got pointed this direction by a member of another camaro forum I'm on. Do you know if there's a good way to identify which 350 I have, by casting numbers on the block or otherwise? I'm curious to see, since the receipts I saw for work didn't really specify anything, and for all I know, it could really be a 305 I suppose.
http://www.mortec.com/castnum.htm
JamesC
Car: 1986 Z28 Iroc
Yeah, I was planning on swapping all my fluids to synthetics, did the engine oil, trans and rear diff were next on my list. I have a few cars, so I'm planning a bulk purchase of some of the fluids. Got 2 Jeeps, a Dart, Dodge Truck, and teh Camaro. Want them all running all synthetics.
Car: 1986 Z28 Iroc
The casting number is found behind the head on the driver's side. Run the number through the following site:
JamesC
JamesC
Car: 1986 Z28 Iroc
I've got valvoline full synthetic in it for oil right now. I wont run non-synthetic oils in my cars anymore, no reason to abuse them like that.
someone972
Aug 30, 2015 12:52 AM
