wiring tcc lock up without opening pan.
Old Feb 23, 2010 | 07:31 PM
73duster's Avatar
I currently have a 91 z28 with 700r4. I will be eliminating the stock computer and will need to wire up the lockup. The kits i've seen have parts for the inside of the trans. Is there any kit that i can use that does'nt require opening the pan? Would'nt the trans already have the necessary stuff? It currently works now, so could i just wire up everything else outside the trans? I really would rather avoid dropping the pan.
Old Feb 23, 2010 | 08:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: wiring tcc lock up without opening pan.
You can, yes. How you do it depends on whether you have a NC or NO 4th gear switch.
Old Feb 23, 2010 | 09:26 PM
73duster's Avatar
How do i know if it's n.o. or n.c.?
Old Feb 23, 2010 | 10:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Put a test light or measure the voltage across pins A and B with the connector plugged in, and the key in the on position with the engine stopped. If the light is on/+12v, it's an N.C. switch. If it's off, it's an N.O. switch.
Old Feb 24, 2010 | 09:24 AM
73duster's Avatar
Where is connector a & b? I'm sorry, i just want to be sure. Can you recommend which kit to go with if it's N.O. or N.C.? Thanks, you've been great in helping.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
