Wheel stud length for new rims
Old Mar 3, 2010 | 12:57 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Just bought new rims and tires. I bought summit fast five wheels. 15x4 with 1.750 backspacing up front and 15x10 with 6.5 backspacing in back. I just test fitted the rim for the hell of it and the 12mm studs I have on now are way to short. My rearend is getting rebuilt shortly and my new axles are dual drilled for 7/16 press in and 1/2 in screw in studs. I was going to get the press in studs but I have changed my mind and want the 1/2 screw in studs. Question is how long should I get them ? I was planning on useing open ended 60 degree conical lug nuts which is what i believe i need to use on that rim just didnt want the stud sticking out a mile past the lug nut.
Old Mar 3, 2010 | 01:00 PM
Stephen's Avatar
Car: 87 GTA
Re: Wheel stud length for new rims
Hard for us to say, without knowing the thickness of your wheels hub...Using open-ended or closed-end lug nuts.....
Old Mar 3, 2010 | 01:27 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I figured such, I was hoping someone was running the same setup or close to it. But anyway I have these
http://www.summitracing.com/parts/SUM-521-5162PS25/
Where do i measure on the rim to find out the hub thickness ?
Old Mar 3, 2010 | 01:41 PM
Stephen's Avatar
Car: 87 GTA
I believe the rule of safety is like for thread engagement, 75% of the lug diameter.
Personally? I go for 100% engagement of threads, if not an extra turn on any wheel. I run the stock lug nut caps on mine they engage just fine. Then again, I run the early ROH Snypers that were specifically designed to fit 3rd gens so....
Old Mar 3, 2010 | 01:42 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
deleted
colton_carlson
Mar 8, 2019 12:21 PM
Djmathis123
Sep 29, 2015 01:36 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
