3.27's to ?????
Old Mar 15, 2010 | 06:26 PM
Samdweezel05's Avatar
3.27's to ?????
Went from a stock tire size to a 285-35/18 in the rear. I want to change the gearing to get back some of the grunt that I lost and maby even gain a bit. Looking at a 3.73. Would a 4.10 be too much? Right now I cruise at 1300 rpm's at 60 MPH. It's just a 9 bolt but I would add a locker of somekind wile I was in there and get rid of the factory limited slip carrier. Thank's
Old Mar 16, 2010 | 12:42 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: 3.27's to ?????
if you want an answer from those that have an answer, post your specs, engine stock/modified/or built... type of tranny, any mods done to it... ? regardless of the info I don't have an answer, but when those that would have an answer they'll appreciate the added info you provide them with...
Old Mar 16, 2010 | 07:39 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 3.27's to ?????
With the 9-bolt rear your options are few. Gear ratios are 3:45, 3:70 amd a possible 3:73. Also forget about a locker, reason none are available. My opinion would be to leave everything alone or go the 12-bolt or Ford 9" route.
Old Mar 16, 2010 | 03:27 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: 3.27's to ?????
Or...swap in a 10 bolt that already has gears and a posi...
If you buy everything bolt in, you can get a 9" for about 1300 bucks, but have to upgrade to disc brakes, plus the cost of a locker+gear installation cost. $2000? For an almost stock car?
Old Mar 16, 2010 | 06:15 PM
Re: 3.27's to ?????
It's pretty close to stock and I do not need the strength of a 9" or a 12 bolt. I will have to look around to see what gears I can find.
Old Mar 17, 2010 | 06:45 AM
DJP87Z28's Avatar
Re: 3.27's to ?????
Additional advice: NO 10-bolt rear axle PARTS will interchange with your 9-bolt rear. Again NOTHING.....
Old Mar 17, 2010 | 12:06 PM
Re: 3.27's to ?????
LOL, thank's man. I will see what I can find for a 9 bolt. If I don't like what I find I will look into a 4th gen rear end swap.
92projectcamaro
Dec 8, 2015 12:25 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
carattini
Sep 10, 2015 07:46 AM
scottmoyer
Sep 7, 2015 07:06 PM
