700R4 build kit good/bad?
Old Mar 25, 2010 | 09:56 AM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
I have listed what the kit includes, i plan on putting it behind a 383 stroker 450hp and 440tq. The price is $515 is this a scam or a legit kit. It also says its rated for 575hp. Also it asks if i want a TransGo Separator Plate and a GM Reverse/Input Drum would i need these parts for my aplication? Thanks, Gary
"Front Pump"
Seal retainer
Seal, late design
Teflon bushing, late design
10-vane rotor with vanes, slide, rotor guide & pin assembly
Trans-Go Steel rings & priming spring
Intermediate/reverse boost valve, (.296)
Main boost valve, (.500)
Stator support
"Clutches, Steels And Pressure Plates"
4 Reverse/input clutches, Borg-Warner .078
3 Reverse/input steels, Turbulator .078
1 Waved reverse/input steel
5 Forward clutches, Borg-Warner .080
4 Forward steels .078
1 Waved forward steel
2 Overrun clutches, Borg-Warner .078
2 Overrun steels .092
5 Low/reverse clutches, Borg-Warner .087
5 Low/reverse steels, Turbulator .068
8 3-4 clutches (Hi-Energy), Borg-Warner .080
7 3-4 Kolene steels; 5-.060, 2-.080
2 3-4 pressure plates .128
1 3-4 snap ring .062
Sealed Power Beast sunshell
Borg Warner 26 element input sprag
Trans-Go HD replacement forward & 3-4 release springs (good up to 7,800 rpm)
Input to output shaft seal (Viton)
Borg-Warner Hi-Energy 2-4 band
2nd gear servo, Corvette
Borg-Warner low/reverse roller assembly
Paper & rubber (gasket) kit
New governor gear
Case connector 3 prong
Transmission filter (OEM)
Converter solenoid & governor filter
Bushing kit with 3 teflon
Thrust washer kit
Sealing ring kit
HD Torrington Bearing kit
TransGo Shift kit (Street/Strip) w/accumulation for nice part throttle shifts
Vamac 3 lip rear seal (prelubed)
New accumulator piston & oem pin for 2nd accumulator
Heavy Duty input shaft checkball capsule
Complete description of parts in the rebuild kit:
Old Mar 25, 2010 | 10:11 AM
Gary Berg's Avatar
Axle/Gears: Posi.
Re: 700R4 build kit good/bad?
http://www.700r4l60e.com/store/produ...&cat=19&page=1
Old Mar 25, 2010 | 11:21 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Sounds like Dana's Street / Strip kit from Pro Built...I don't have much to compare it to, but I'm pretty happy with the way my trans performs after installing what I believe is the same kit you are describing.
Old Mar 25, 2010 | 11:39 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I bought the same kit. Very happy with the contents. Hopefully I'll have it on the road by next weekend.
I have not heard anything bad from anything that Dana has sold. If you have the kit built as he says to build it, you shouldnt have any problems. As far as asking about the other stuff, give him a call. If he doesnt answer he will call back. Thats what I did. And I recommend a new seperator plate. Cheap insurance.
Old Mar 25, 2010 | 01:40 PM
Gary Berg's Avatar
Axle/Gears: Posi.
thanks guys that helped alot now i know wat my first paycheck this summer is goin toward.
Old Mar 27, 2010 | 08:48 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Dana is a VERY stand up guy. I bought the roadrace kit from him per his recommendations. He even called me back at 11 o'clock at night to help me with my order. Will most definately do business with him again.
Old Mar 30, 2010 | 07:09 AM
Gary Berg's Avatar
Axle/Gears: Posi.
wow i like what im hearing
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
someone972
Aug 30, 2015 12:52 AM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
