T10 anyone
Old Mar 30, 2010 | 10:47 AM
beatereater's Avatar
Car: 84 Trans am
Engine: 355
Transmission: TH400
Axle/Gears: 343 rear end
T10 anyone
i was wondering how a t10 would do bolted to a 355 (if it would bolt up)
Old Mar 30, 2010 | 11:36 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T10 anyone
It will bolt up as a muncie or T5 would. Transmissions bolt to bellhousings, and bellhousing bolt to engines. There are dozens/hundreds of combinations of engine/transmission pairs, the interesting part is the clutch/activation mechanism.
Are you asking how long it would last before failing?
Old Mar 30, 2010 | 12:26 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Re: T10 anyone
I second that, all you should need is the correct bellhousing, IIRC 82-83 F-body's could be had with factory T10 4 speeds, so the parts are out there to do a complete "factory" swap. However if you plan on making good power than a Scattersheild from lakewood or the like would be a wise choice, you dont want the clutch to come apart and loose some fingers and toes to boot...
T10's are pretty durable too, more so that Muncies ever where despite their reputation. The 350 in my Nova blew my M20 muncie out twice, then I rebuilt with a thicker front case and M22 gear set but I eventually went with a Mopar A833 which is in the car now. It allows me to dump clutch and grab gear like Ronnie Sox used too lol (7000rpm launch, 7500rpm shifts, 11.2-11.0 in the 1/4)
jtwoods4
Jan 22, 2018 01:13 PM
beachrodder
Aug 7, 2015 04:27 PM
Air_Adam
May 3, 2006 07:26 PM
Skatepunk60
Feb 11, 2006 04:47 PM
Air_Adam
Jul 9, 2005 10:49 AM
