T5 clutch & flywheel question, seeing mixed answers
Old 04-02-2010, 12:21 AM
nighthawk355x's Avatar
Car: Caged 92 Z28 1LE
Axle/Gears: 3:42
Looking for a clutch for my 92 305 T5 car and I seem to be getting conflicting info when searching. I see posts saying the T5 has a 27 spline input shaft and I see posts saying 26...what gives?? Pick one.
Also, just wanted to double check flywheel tooth count. This is what I'm looking at, if anyone can tell me if these will work...
http://www.summitracing.com/parts/NAL-14088648/
http://www.summitracing.com/parts/RA...RO&prefilter=1
http://www.summitracing.com/parts/RAM-BU656/
Old 04-02-2010, 12:55 AM
kizmaro89's Avatar
Car: 89 Camaro RS
Engine: LM7
Re: T5 clutch & flywheel question, seeing mixed answers
T5 flywheels have a 153 tooth count. My clutch i removed an hour ago is 26 spline.
Old 04-02-2010, 07:35 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
T5 has a 26 spline input and a 27 spline output and as stated above, 153 tooth flywheel.
Old 04-02-2010, 09:43 PM
Pat Hall's Avatar
The clutch and the pilot busing you listed should work fine. Of course the flywheel you linked is too big. For your flywheel you need to make sure to get one for an 87-92, 1 piece rear main seal, 153 tooth count. You're probably better off buying or ordening the flywheel from a local parts store. The last time I looked on Summit and Jegs it was hard to find the right one for our cars. Most of the ones they sell are either 2 pc. rear main seal, or don't have the correct balance. Actually, I just found the right one on Summit, but it's kinda spendy. It'd probably be cheaper from a local parts outlet. Here's the link for the Summit one, it's a GM Performance flywheel, and it's the 16 lb. one that 3rd gen Z/28's used. http://www.summitracing.com/parts/NAL-14088646/ They also have the heavier "RS" flywheel for about 20 bucks cheaper. http://www.summitracing.com/parts/NAL-14088650/
BlackphantomZ28
04-24-2016 08:14 AM
Trickskier
08-29-2015 01:12 PM
Bryan F
08-18-2015 02:28 PM
redmaroz
08-16-2015 11:40 PM
bamaboy0323
08-15-2015 07:20 AM
Quick Reply: T5 clutch & flywheel question, seeing mixed answers
