recent change
Old Apr 2, 2010 | 12:49 PM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
recent change
i own a 92 rs that was factory tbi i changed it carb 350.i have been reading that it is a must to wire up a lock up kit for fourth gear.i have the tci kit.it is a 700r4 trans but my ? is.why do i need this if im leaving the eck hooked up in the car doesent it run off the ecm? or not
can any one explain?
Old Apr 2, 2010 | 01:03 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: recent change
No need to buy a lockup, I went from TBI to carbed 350 and had my transmission built and it locks in just fine into OD around 55-60. It runs off hydralic pressure so once the pressure builds high enough it will fall into OD. Most if not all 700R4's are run off hydralic pressure and don't have much for electrical inside them.
Old Apr 2, 2010 | 01:22 PM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
Re: recent change
why is it that in the carb forum they say it is a must.it will go into fourth gear but the tourq converter will not lock up some guys have said that it has burnt their trans up and some say it works fien read through my thread in carbs called tbi to carb answers c if i missed anything thanx
Old Apr 2, 2010 | 05:09 PM
Engine: Vortec 357
Re: recent change
it will go into 4th just fine, and all depends on the setup you have. With mine It would go into OD just fine, with my new setup it hasn't yet, but I also havent had it out on the freeway over 70mph to see if it will lock up.
bryan623
Mar 22, 2021 06:43 PM
Redvert88
Convertibles
Apr 8, 2016 01:59 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
evan555222
Aug 22, 2015 07:14 PM
