clutch pedal
Old Apr 2, 2010 | 04:36 PM
andrew22888's Avatar
clutch pedal
I have a 84 camaro berlinetta i'm putting a wc t-5 out of a 89 camaro. The only thing i'm missing is the clutch pedal master cylinder. I found this set up on ebay. I was wondering if it would work with a stock slave cylinder. And if it should work with my car.
http://cgi.ebay.com/ebaymotors/ws/eB...ategory=107061
Thanks for all the help
Old Apr 2, 2010 | 04:47 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: clutch pedal
I'm going to go out on a limb and say no. The stock master cylinder sits at a steep angle. If all you need is a master cylinder you can get them at Auto Zone for less than $50.
Old Apr 2, 2010 | 04:51 PM
Re: clutch pedal
I'am in need of the clutch pedal and master cylinder. Will a t56 clutch pedal assembly work.
Old Apr 2, 2010 | 06:17 PM
built91Z28's Avatar
Re: clutch pedal
Not sure on that. Since I'm not doing the typical T56 swap I'm getting 3rd gen pedals to go with the 3rd gen clutch setup. Tomorrow I'm going to all the junk yards around here to see if I can find some. As a last ditch plan, Hawks sells the pedal assembly new for $150. I really dont feel like paying that much though.
Old Apr 2, 2010 | 08:44 PM
Pat Hall's Avatar
Re: clutch pedal
You CAN use the T56 pedals/clutch M/C, but it requires some modification. You have to cut off the 4th gen gas pedal since it's part of the clutch/brake pedal assembly, whereas it's separate on the 3rd gens. Not hard to do, but it's easier to just get a set of 3rd gen pedals w/hydraulics. I sure as hell wouldn't pay $150 either. If you scrounge around on ebay, or go to a local junkyard and find a manual trans equipped V6 3rd gen, you can usually get what you need for less than $100. Just type in "camaro 5 speed" in the search bar on ebay, and there's usually multiple sets of 3rd gen pedals on there for cheap. Btw, do yourself a favor and read the tech article here on the site about swapping a 5 speed into an auto car. It explains everything really well, and I think it even has some good pics of the pedal/master cylinder installation, including good instructions on how to cut the holes in your firewall correctly. I also remember a post here from member Benny K about a T5 install that has excellent pics for cutting the shifter hole and the holes for the clutch linkage.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
