Will not downshift
Old Apr 5, 2010 | 02:07 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Will not downshift
My 88 trans will not downshift out of any gear when I hit the gas. It will do it when I slow down, but not when I put the gas through the floor. It doesnt unlock the converter either.
I just had the trans in for a rebuild and a new converter. The lockup clutch was shot and the trans was a little wore out. It did downshift prior to the rebuild, but the lockup did not work.
Sometimes the 1-2 shift is really hard as well. Throttle doesn't affect shift points.
This is getting frustrating and I don't really want to take it to a shop to let them "troubleshoot" for six hours.
Old Apr 5, 2010 | 02:20 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: Will not downshift
I hate to sound so cliche here but is your TV cable adjusted properly cause that's what it sound like.
The last 700R4 I had behaved exactly the same way because my dumbass didn't adjust it right and I didn't find out til 3 months later when I lost every forward gear.
EDIT: Nevermind I just read that you have a FMVB. You're better off haing someone more experienced with trannies chime in.
Old Apr 5, 2010 | 02:29 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
This is in a different vehicle. I suppose that would be important info. Its an 88 700r4. I have adjusted the schize out of the cable, also had an experienced tech do it.
Prodigious
Nov 7, 2020 09:23 AM
tyeo098
Nov 30, 2015 06:27 PM
someone972
Aug 30, 2015 12:52 AM
JeffP
Jan 4, 2001 11:46 PM
