T5 fluid,how much? what kind?
Old Apr 6, 2010 | 12:09 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Hey guys ive heard mixed subjects on this of what kind of fluid to use in my T5..also how much do i put in? id like to just put it in through the shifter so i dont have to crawl under it and fill it that way.Thanks.
Old Apr 6, 2010 | 12:36 PM
Thirdgen6.6l's Avatar
Car: Red 1988 Iroc-Z hard top
Engine: 305 ( LSX swap soon )
Transmission: 700r4 ( T-56 swap soon )
Axle/Gears: What ever gear that come in 88 iroc
Re: T5 fluid,how much? what kind?
I dont know much about third gen, but I alway like redline oil for high performing car.
On my Mustang t5 I use Red Line Oil ATF-D4 and fill about 3 quart.
Old Apr 6, 2010 | 12:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you've read the sticky, then you know that the whole business seems to be a toss-up. That said, the following is from a Chilton's manual:
All 4-speed and 82-84 5-speed manual trans use only SAE 80W or SAE 80W/90 GL-5 gear lube (SAE 80W GL-5 in Canada).
85-86 and 88-92 5-speed manual trans use Dextron II automative trans fluid.
87 5-speed mannual tans use SAW 5W-30 manual transaxle oil (GM #1052931).
I'm not really sure how much fluid the trans holds as I usually follow the "fluid trickling out of the hole" method. If you purchase a pump bottle, filling is easier.
JamesC
Old Apr 6, 2010 | 01:10 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
hmm ok sounds good..ive been told to use some lucas in it too think it would be a good idea?
Old Apr 6, 2010 | 01:24 PM
No please do not use lucas on any thing.
Old Apr 6, 2010 | 01:29 PM
84z .....'s Avatar
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
No please do not use lucas on any thing.[/quote]
???? why???
Old Apr 6, 2010 | 01:44 PM
???? why???[/quote]
Gear Oil FAIL
http://www.syntheticwarehouse.com/br...lube_study.pdf
Lucas Oil Stabilizer FAIL
http://www.bobistheoilguy.com/images/lucas/lucas.htm
lucas product is mostly thick up the oil, if you engine or tranny is about to fall apart, I might try it. If you have time read up bobistheoilguy.com good site read up, i spend 5 year reading it.
Old Apr 6, 2010 | 01:51 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Thats interesting,ive never heard of that before.
Old Apr 6, 2010 | 02:29 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
I'm gonna fill mine with Redline ATF when the time comes, but any quality Dextron II ATF should do the trick. Gear oil is old and antiquated, I wouldn't use it even if you do have one of the rare T5s that is spec'd for it. And no Lucas, it's a gimmick. Any lubricant you buy today to good to go as it is without any additional additives.
Old Apr 14, 2010 | 09:04 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i went to thenparts store and they said they hold 5 quarts..sounds a bit much but i put 4 in for nw til i pull the drain plug and see where im at
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
