Do you have to replace your rearend to change gear ratios?
Old Apr 27, 2010 | 02:16 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
If you want a different gear ratio in your rear end do you have to swap in a whole new rear or can you just adjust\swap the gears themselves?
Also, if I pop off the diff. cover to get the numbers will the fluid leak out and need replacing?
Old Apr 27, 2010 | 02:44 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Do you have to replace your rearend to change gear ratios?
you can just swap the gears inside the rearend. It is not a simple swap. It must be set back up correctly or the gears can be ruined.
Yes if you open the cover all the fluid will drain out.
Old Apr 27, 2010 | 04:17 PM
Zerocyde's Avatar
Car: 88 Camaro
Axle/Gears: 4.11
Thanks for the info!
(part a): And once done you have to change the speedo gear or whatever it's called by the tranny right? Is that only for cable speedos? Like, if I was planing on replacing my speedometer anyway, could doing so at the same time save me any work or do I have to change that speedo gear regardless?
(part b): It's just standard gear oil right? Do I need any special kind?
Old Apr 27, 2010 | 04:30 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Hmm! I always thought a new pumpkin was needed, so a 2.72 (forgive me, i forget the exact number if that's not it) to a 3.23 (again... can't remember the exact number) is possible in the stock axle?
Old Apr 27, 2010 | 04:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Most of your questions, to include the ones above, can probably be answered in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 27, 2010 | 07:33 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
2.73 to any gear ratio made for the 7.5" is possible in the stock housing. The housing is just that, a housing. The only thing that sometimes has to be changed is the carrier because of different thicknes's.
Old Apr 29, 2010 | 08:44 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Thanks, that's good to know ahead of time. I'm leary about changing out the whole back end when i really don't want to, i'm happy with what's there for now.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
