TH350 question
Old Apr 28, 2010 | 12:28 AM
tomtom420's Avatar
Car: 86 Grand National / 90 Formula
Engine: 3.8 V6 / Procharged 5.7tpi
Transmission: 700R4 / 700r4
Axle/Gears: 3.42's / 3.23's
TH350 question
Can you use the same cross member from a 700r4 on a TH350? Or do you need a different one. Thanks
-tom
Old Apr 30, 2010 | 10:23 AM
Penix's Avatar
Car: 1979 Camaro Sport Coupe
Engine: 350 LM1 with 083 2.02/1.60 heads
Transmission: TH350, soon to be 2004R
Axle/Gears: 2.41, soon to be 3.42
Re: TH350 question
You will need a different one
Old Apr 30, 2010 | 10:28 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: TH350 question
Gonna need something along the lines of this
http://www.umiperformance.com/catalo...roducts_id=138
Old Apr 30, 2010 | 06:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: TH350 question
It could be modified. When I was using a Spohn torque arm and crossmember, it was for a 700R4. I swapped in a TH350 and modified the mount slightly. The TH350 sits roughly 2" forward from when the 700R4 mount is. Worked fine for me.
Old May 5, 2010 | 09:53 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: TH350 question
I had used a b&m adapter kit when i swapped mine into the 89 RS. what are your plans for the torque arm? might want to think about that too when you're looking into your different options
Old May 5, 2010 | 11:59 AM
jake1992jake's Avatar
Car: 1989 camaro rs
Engine: 406 chevy
Transmission: turbo 350
Axle/Gears: 3:73 posi
Re: TH350 question
can i use my stock torq arm and modify my 700r4 tranny mount i will be using a turbo350
Old May 7, 2010 | 09:04 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: TH350 question
Just buy the b&m kit made for this change. Its like a hundred bucks and it works great. You can use the stock torque arm and stock crossmember with that kit. However, if your luck is as good as mine, just after I did the swap, I tore the bushings out of my crossmember and had to buy a new one. But still, the kit is the way to go.
Old May 7, 2010 | 09:05 PM
Car: 1989 camaro rs
Engine: 406 chevy
Re: TH350 question
where u get it from
Old May 8, 2010 | 11:10 AM
dellman83Z's Avatar
Re: TH350 question
Here ya go http://www.summitracing.com/parts/BMM-30299/
Old May 8, 2010 | 04:02 PM
tomtom420's Avatar
Re: TH350 question
I've been asking a question about my torque arm mount and no one has been answering, so maybe you can help me. I have a TH350 and i already have the bracket attached to the trans but how does the torque arm connect to the bracket?? Is it shown in that kit, because it doesn't look like theres anything for the torque arm to slip into?
Old May 8, 2010 | 04:58 PM
dellman83Z's Avatar
Re: TH350 question
You reuse one off your 700r4. I know there were instructions in the kit, but if I recall, you use some supplied bolts(hardware store bolts) to attach it to the bracket off the trans. I will have my car up in the air tomorrow, if I remember, I will take a closer look at it and possibly take some pics for you.
Old May 9, 2010 | 01:25 PM
tomtom420's Avatar
Re: TH350 question
Thanks man I really appreciate the help, and if you could show me some pics to reference that would be great. Either way thanks again.
-tom
Old May 10, 2010 | 02:39 PM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Re: TH350 question
Yeah my crossmember worked we just had to slot the bolt holes a little.
Old May 12, 2010 | 02:37 PM
dellman83Z's Avatar
Re: TH350 question
Sorry I have not gotten back to you, I have been working too many hours to work on my car, so hopefully in the next couple of days I will snap a pic for you. Just FYI, if you look on summits site, I believe they have the instrucions in pdf format for the conversion kit.
Old May 17, 2010 | 10:08 AM
dellman83Z's Avatar
Re: TH350 question
Sorry it took me a bit to get back to you, been quite busy. I could not get any clear pics of the torque arm mount, but I will describe it the best I can. You need to remove the tq mount off your 700r4. What you use is the front piece of the two piece mount and the rubber inside of it. Basically, it just bolts up to the bracket with the bolts the kit originally came with and sandwiches the rubber in the middle. There are also two tangs that are on the bottom of the tq mount, those just sit the the slots of the new bracket. The bracket is tapped for them, so just go to a hardware store and get some bolts that thread into the holes. If I remember right, I had to bent the old mount piece to line up with the bolt holes.
Old May 19, 2010 | 05:29 PM
tomtom420's Avatar
Re: TH350 question
Ok what are "tangs", and how does the front peice go on when there is a long bolt attached to the mount that doesn't line up nor size up to anything. The 700r4 mount is too long and doesn't line up to bolt anywhere. Here is a link with pics of old mount on 700r4, th350 bracket, and th350 bracket with mount mocked up. Take a look and tell me what i'm missing.thanks
-tom http://s542.photobucket.com/albums/g...20arm%20mount/
Old May 20, 2010 | 10:24 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: TH350 question
I used a crossmember from an '82 with a 4-spd manual... worked fine?
MustangBeater20
Oct 29, 2022 09:20 PM
LittleFranks
Sep 17, 2015 12:22 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
