will a t5 hold up to a 350 tpi
Old Sep 11, 2010 | 07:25 PM
  #51
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: will a t5 hold up to a 350 tpi
this thread simply has 50 posts more then it needs to!
YES, a t5 will hold up..but powershifting/clutch dumps/missed gears are going to destroy one, or shorten its life drastically.
Please do not listen to 75% of the members, in my experience with this website over the last 10 or 15 years however long its been, Most are children, who have no experience, and are simply spewing garbage based on what their buddys dads uncles grandfather did 15 years ago..
Simply put, it will survive, but beating on it will shorten its life, just like with any other transmission.
and to EFIhead, yes, i have a hurst shifter..i like it
Old Sep 13, 2010 | 02:13 AM
  #52
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Originally Posted by 87WS6
The World Class T5 will not hold up to anything but driving Ms. Daisy behind a performance engine. It is only rated to handle 300 foot pounds of torque and no more. This isn't conjecture, it is fact. Borg Warner and General Motors were keenly aware of this fact. The L98 and any real performance engine in these cars will exceed that amount of torque easily. A shifter can't change that. The casing is weak and so are the stock internals. A single billet retainer can't change that. If yours has held up then you've either gotten lucky, or you aren't "abusing" it. Or some might say, "using it." Its either that or you must have the Arnold Schwarzenegger of all T5's or something.
Hello 87WS6!!
The T-5 was rated at 295, and the WC T-5 was rated at 300 lb-ft of torque, they will handle more!!
As with all things that have a "safety rating" there is always a "safety margin", and this is the case with the T-5's!!
I have a T-5 in my car. My car is rated at 295 lb-ft of torque at 3200 rpm, based on your info, my T-5 should "grenade" after shifting from second to third the first time!!
If you abuse things, things will break, if you take care of things, with occasional abuse, they should last!!!
The "safety margin" for the T-5, and the WC T-5 was not enough for GM to be satisfied that there would not be an unusual amount of warranty claims, coupled with the "CAFE" regs, that's why the 350 didn't have a T-5!!
@ 89fbirdformula, I agree with you 100%!!
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
