Transmission/speedo problem
Old Apr 29, 2010 | 10:28 PM
nateg's Avatar
Car: 89 Camaro Iroc-Z
Engine: 383 Stroker
Axle/Gears: 3:27
Alright, ever since I bought my Iroc it has had a shaky speedometer and I got the gear replaced cause it was really wore down to a complete circle and now after about 6-7 months its shaking again I was wondering if anyone knew if this is an actual tranny problem or what was up.
Old Apr 29, 2010 | 10:34 PM
Vice04's Avatar
Car: 84 Monte
Engine: 355 Chevy HSR
Axle/Gears: 3.90 Ford 9"
Re: Transmission/speedo problem
Gear in the trans or gear on the pickup?
Old Apr 29, 2010 | 10:36 PM
nateg's Avatar
Engine: 383 Stroker
Axle/Gears: 3:27
the little plastic speedo gear in the trans
Old Apr 29, 2010 | 10:49 PM
Vice04's Avatar
Car: 84 Monte
Hmm... That is odd, I never had that happen, is it a cable speedometer?
I did a search and only found this:
http://www.allfordmustangs.com/forum...do-i-need.html
They had the gear wear problem too, but never actually said what caused it.
The only thing I can think of would be incorrect gears, or something is causing the plastic gears to drag (like the cable in a mech speedo) If yours is cable, try to spray some WD-40 down it after pulling the cluster forward.
Old Apr 29, 2010 | 10:57 PM
nateg's Avatar
Engine: 383 Stroker
Axle/Gears: 3:27
It is a mech speedo and the cable turns fine so Im thinking it may be the incorrect speedo gear....the mechanic i took it to when i was clueless about it said my transmission is messed up but in my opinion it shifts and works just fine so I think he may be wrong on that note
Old Apr 30, 2010 | 06:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Did you take a look at the drive gear? If it's gone bad for some reason, its condition might causes issues with the driven gear.
JamesC
Old Apr 30, 2010 | 07:19 AM
nateg's Avatar
Engine: 383 Stroker
Axle/Gears: 3:27
That is a very good idea as a matter of fact
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
