Which OE TV cable for TPI/TH350 combo?
Old Apr 30, 2010 | 10:27 AM
Penix's Avatar
Car: 1979 Camaro Sport Coupe
Engine: 350 LM1 with 083 2.02/1.60 heads
Transmission: TH350, soon to be 2004R
Axle/Gears: 2.41, soon to be 3.42
Converting my '79 Camaro to TPI with the current TH350 (till I can afford the 2004R) and I need to know which TV cable to use. The TPI setup is from an '86 Camaro.
Thanks guys!
-Joel
Old Apr 30, 2010 | 10:48 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Which OE TV cable for TPI/TH350 combo?
I don't know about OE but someone used Lokar.
https://www.thirdgen.org/forums/tpi/...-th-350-a.html
Old Apr 30, 2010 | 10:50 AM
jmd's Avatar
jmd
A vote for B&M
https://www.thirdgen.org/forums/tran...cable-tpi.html
Old Apr 30, 2010 | 10:55 AM
Penix's Avatar
Yeah, the Lokar ones are nice but a little too flashy for me, plus I'm trying to keep this somewhat on the cheap. Under that link to the B&M piece someone mentioned TCI, I'll check them out, but I'd really like an OE unit if possible.
Old Apr 30, 2010 | 11:01 AM
jmd's Avatar
jmd
I know what you mean; I'm not chrome and braided if I can avoid it.
Old Apr 30, 2010 | 08:41 PM
Penix's Avatar
Okay, I found the answer to both my questions...
A universal kickdown cable that works well for this application is Fitzall # K35955u (There's also K35955 & K35955B) which can be found for around $20-$25 shipped and looks absolutely stock!
As for a throttle cable, apparently a throttle cable from a late 80's S10 Blazer works perfectly and also looks absolutely stock as well! This part can also be had from RockAuto.com for about the same price shipped.
Well I hope this info helps you guys as much as it's helped me!
- Joel
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
