Speedometer firebird 1987
Old Apr 30, 2010 | 01:44 PM
crazyeight's Avatar
Car: Pontiac Firebird 1987
Engine: 305 4bbl
New problem here.
Yesterday i was driving my bird around and no problem so far but i stopped at a gas station and when i started her up again my speedometer dont work no more.
What could be the problem?
searched on the forum but couldnt find anything.
Ive checked all fuses but their fine.
Old Apr 30, 2010 | 01:49 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: Speedometer firebird 1987
All the gauges are on one fuse. If that fuse went, you'd know it. As for the gauge itself it could be the sending unit. It could be a short or a broken electrical wire, a broken speedometer gear. (Technically possible I suppose, but unlikely.) It could also be a problem with the cluster, etc.
Old Apr 30, 2010 | 02:01 PM
crazyeight's Avatar
Engine: 305 4bbl
Aha ok
Will take a closer look tomorrow. check some wires behind the dash tomorrow.
When i hit a roadbump the speedometer jumps up to. Feels like its a wire problem. Like when i hit a bump it got contact or something.
Excuse my bad english
Old Apr 30, 2010 | 02:06 PM
87WS6's Avatar
Originally Posted by crazyeight
Aha ok
There is a connection that comes up from the transmission/speedo gear to the VSS. That's what I'd check first.
Old Apr 30, 2010 | 02:07 PM
crazyeight's Avatar
Engine: 305 4bbl
Call me stupid but what is a VSS?
Old Apr 30, 2010 | 02:13 PM
87WS6's Avatar
Vehicle speed sensor.
Old Apr 30, 2010 | 02:16 PM
crazyeight's Avatar
Engine: 305 4bbl
Aha hehe now i know
Old May 2, 2010 | 02:28 AM
crazyeight's Avatar
Engine: 305 4bbl
Little update
Havent had time to check vss yet but i noticed that its not only the speedometer "needle" that doesent work.
Its the whole thing "tripmeter, km meter and speed" so its the whole thing thats dead.
Will check vss under the car today.
Old May 2, 2010 | 12:42 PM
crazyeight's Avatar
Engine: 305 4bbl
Was under the car before but couldnt find any obvious brakes on cables or anything.
Tried to get the dash out but couldnt get it out. Anyone with a guide for that?
The left part of the speedometer wouldnt come out and i didnt want to pull incase i brake anything. so a guide would be helpful.
Took all panels down even the top one "where the speakers are"
Old May 8, 2010 | 10:29 AM
crazyeight's Avatar
Engine: 305 4bbl
Problem solved
Its my speedometerwire thats dead
Thanx for all help
Old May 24, 2011 | 08:42 AM
11ellswray's Avatar
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
old post i know and im sorry, my 1986 has a dead speedometer,and i just replaced the gear,thing still wont work. what is this wire you speak of? and is your speedometer mechanical or electronic? thanks, sorry again about trollin up an old post
Old May 24, 2011 | 10:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Your 86 Camaro is mechanical. Check the following thread for possible fixes:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old May 24, 2011 | 11:43 AM
11ellswray's Avatar
Engine: 385" SBC
i replaced the driven gear, the drive gear appears to be in great shape, when i spin the end with my hand the speedometer will get to 15mph, i have already taken the cable out and regreased it.
quite frustrated
Old May 24, 2011 | 11:57 AM
11ellswray's Avatar
Engine: 385" SBC
i think that my gear might not be seating correctly into the tailshaft, just a guess though. so i put the gear in 7 different times, each time thinking that i had solved all of my problems and that life was great, untill i go to test it and the speedo doesnt even bounce.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
AUZ28
Oct 12, 2015 08:40 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
