vibration at 2500 rpm
Old May 4, 2010 | 12:41 AM
mmash10's Avatar
88 rs 2.8/5speed........
my motor runs fine,until about 2500 rpm in any gear. then theres a massive vibration ... i replaced the motor mounts and the tanny mount, but it still wants to shake like crazy at about 2500/2800pm..also the shifter will bounce up and down a little. top speed is about 60 mph .. any help will do.....
Old May 4, 2010 | 12:44 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: vibration at 2500 rpm
that would sound like your torque arm bushing, it will be locked in place with rivets, you will need a dremel or chisel... I believe you will have to remove the entire torque arm...
now if you get a klunk from a start, then you will need a tranny mount... make sure you get polyurethane...
Old May 4, 2010 | 04:42 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
i'm not 100% sure if that's the cause of my current vibrations but i'm at the point of kicking the PU energy suspension tranny mount down the next ditch and getting a new rubber mount.. could be some other issue though so take this with a grain of salt.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
MartinD
Sep 22, 2015 02:27 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
