700r4 pan leaks
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
700r4 pan leaks
Just doubled checked and its the 4L60E formerly known as the 700r4 :P sorry
Hey all just got my car out of storage and found a nice small puddle of trans fluid under the car, thinking about redoing the gasket, and filter. how much fluid should i replace after doing this?
Engine: 350(5.7L)
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: 700r4 pan leaks
4-5 qts if your just replacing the filter/gasket. 11-12 qts if your starting from "scratch".
Re: 700r4 pan leaks
Just remember to start the car, hold the brake, shift through all of the gears slowly and check the trans dip stick while its running at operating temp. I dont think there is a better way when you dont know how much is actually in the trans or how much leaked out. Mine leaked to not to long ago. I just tightened the bolts on the pan for now and it stopped. I'll do the gasket later.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
