Servo Cover partially came off? Why?
Old May 10, 2010 | 02:11 PM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
Cover is hanging and lost all fluid. Bad cover o ring or was it not seated properly. Guess it was rebuilt with a shift kit by the previous owner.
should i just hammer it back in and reapply the c clip or replace the o ring first? or is there be something deeper in the tranny that caused this?
thanks,
Drew
Old May 10, 2010 | 02:34 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Servo Cover partially came off? Why?
thanks,
Drew
Usually its just that the snap ring wasn't installed properly. I had it happen on my car after a fresh rebuild once. killed all fluid before I could shut the car off.
Old May 10, 2010 | 03:11 PM
I don't see how I can get it back on without removing transmission.
Old May 10, 2010 | 03:47 PM
Drop the crossmember, let the trans tilt back. Make sure the dizzy doesn't hit the firewall. Should give enough working room.
Old May 10, 2010 | 04:07 PM
working with ramps in the driveway. with basic hand tools. time to find local help I think.
Old May 10, 2010 | 09:39 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
its an easy job, just remove the snap ring, cover, pull the first piston replace oring seal, vasoline it up, clean the snap ring groove, reassemble and make sure its seated right this time. Maybe buy a new snap ring?
Old May 11, 2010 | 12:30 PM
raining right now. as soon as i get stands that hold her high enough to move my elbows. cant get leverage so that the cap comes out. maybe get a screw driver in there.
Old May 11, 2010 | 03:23 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
if I remember right, there is a part that is notched out, you need to stick a pick in there and pry out the seal in order to get the cover off. Then take a big pair of channel locks on the cover and kind of finegal it out.
Old May 19, 2010 | 03:39 PM
finally got the time.
pulled cover off oring is fine but the little black gasket was torn in the middle (not the factory cut) so the ring was in two separate pieces.
Could this have been from me twisting and pulling to get the cover off?
also does anyone know any tricks to get the snap ring back on the cover?
Old May 19, 2010 | 03:48 PM
or where can i get the proper pliers for the LARGE snap ring on the cover. Ive been reading that normal snap ring pliers are to small.
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
italiano67
Sep 22, 2015 08:42 AM
BWilcox
Sep 20, 2015 12:19 PM
Cleotiz
Sep 16, 2015 08:02 AM
scottmoyer
Sep 7, 2015 07:06 PM
