Servo Cover - Should it be this difficult?
Old May 20, 2010 | 04:20 PM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
I'm trying to put the cover back on, I bought it with the cover partially off, found out the hard way. So i put i new 4th piston ring on and grease and now trying to get the cover back on, I used a pry bar and all i am doing is denting the frame.
I also noticed at the end of the first spring you see under the cover/4th piston. thats the servo? it should be parallel?
mine is sitting kind ****-eyed. the previous owner installed a trans go shift kit. maybe something isn't right beyond the 4th piston that is preventing the cover from sealing properly?
it has to be far enough in that the snap ring sits in the little indentation correct?
I hate to hand it over to a tranny shop for just the cover, but maybe its more than that.
thanks
drew
Old May 20, 2010 | 04:24 PM
Re: Servo Cover - Should it be this difficult?
Some bad pics
Attached Thumbnails Servo Cover - Should it be this difficult?-img00222-20100520-1656.jpg   Servo Cover - Should it be this difficult?-img00224-20100520-1657.jpg   Servo Cover - Should it be this difficult?-img00220-20100520-1514.jpg
PurelyPMD
May 5, 2016 04:57 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
355tpipickup
Sep 13, 2015 11:35 PM
scottmoyer
Sep 7, 2015 07:06 PM
