Whats this bar
Old May 23, 2010 | 04:27 PM
andrew22888's Avatar
Whats this bar
Ok I have a 84 berlinetta just finished my t-5 swap. Bought the car with no motor and no trans. When I installed the t-5 today I noticed a bar going from my rear end up. When I push on the bar it moves the rear end. My car was originally a automatic. Where do I mount this bar. And what is it for exactly. And since my car was an automatic am I going to be able to bolt it to the t-5
Old May 23, 2010 | 06:00 PM
camarofanatic90's Avatar
Car: 1990 Camaro RS
Engine: soon to be 383 stroker
Transmission: t5
Axle/Gears: soon to be 3.73
Re: Whats this bar
it is the torque arm and it will bolt to the side of the t5
Old May 23, 2010 | 09:49 PM
Re: Whats this bar
Does anyone have a picture of this. I don't see anywhere it would bolt to.
Old May 23, 2010 | 10:00 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: Whats this bar
There should be a clam mount on the tailshaft of the t-5.
There are 3 long bolts that go through the tailshaft and bolt to the mount. I'll look for a picture.
Old May 23, 2010 | 11:31 PM
Re: Whats this bar
I found a picture of the bracket. But I only have half and no bolts. Does anyone know where I can get a new one. With bolts and everything.
Old May 24, 2010 | 02:07 AM
Re: Whats this bar
Also is it the same for a automatic transmission also.
Old May 24, 2010 | 11:06 AM
Car: 1990 Camaro RS
Transmission: t5
Re: Whats this bar
it is the same for auto or manual the mount you can buy new the bracket you will have to find on a used car somewhere.
Old May 25, 2010 | 02:21 PM
Re: Whats this bar
What about for a v6 there is a v6 firebird I could go pull some stuff off does anyone know if they are the same
Old May 25, 2010 | 02:54 PM
JTNKTZ's Avatar
Engine: 355/350
Re: Whats this bar
This is wrong. The automatic and manual have different mounts
Old May 25, 2010 | 04:57 PM
Car: 1990 Camaro RS
Transmission: t5
Re: Whats this bar
im sorry i just checked the mounts and they are different. i never looked that close i always thought they were the same.
Old May 25, 2010 | 10:11 PM
Re: Whats this bar
Ok thanks alot guys.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
