Will this rear end fit????
Old May 28, 2010 | 07:24 PM
AWES0ME1's Avatar
Ok, I'm a newb. I'm buying a '91 Camaro RS 3.1 V6 today for 200$ but it don't run, but that's beside the fact (i might be on later to ask how to fix it)... I have been researching a lot in the past 4 days, and i am looking to get this POSI rear end and this is what the post said:
"I have for sale an '87 Camaro Z28 rear end. It has 3.23 gears with a POSI limited slip. It also has disk breaks from a '97 Camaro, and all new wheel studs. Overall it is in really good shape. I am getting rid of it because I will be moving soon and I will not be able to take it with me."
Will this bolt right up to my car? Do i have to get a V8 Tranny? it is a 10 Bolt...
p.s. is 200$ a good price for this rear end?
Old May 28, 2010 | 08:09 PM
Stephen's Avatar
Car: 87 GTA
Re: Will this rear end fit????
Physically, a 87 rear end is a 100% bolt in. If the gears are different than what are in your car now? Your speedometer will read wrong, but that is an easy change of the little gears in the tranny.
Old May 28, 2010 | 08:26 PM
AWES0ME1's Avatar
Yea I think the gears are different (by this I mean I hve no idea, it is 100% stock), is there a post that I can view to change the speedometer? Oh an will the motor push it? (160,000 miles)?
Old May 28, 2010 | 08:45 PM
Stephen's Avatar
Car: 87 GTA
You have a 700R4? https://www.thirdgen.org/speedogear
Old May 28, 2010 | 08:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You may find the following info on the 10-bolt interesting:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old May 28, 2010 | 10:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your 91 will have 28 spline axles and whatever carrier it came with, open, posi or gov-lock. The 87 will have the smaller 26 splines unless it's been upgraded. Assuming you have an 700R4 tranny, you already have 3.23 gears. If a manual, you have 3.42 gears.
For $200, you're getting 97 disk brakes since using the posi with the smaller axles is a step backwards. You'll need a 28 spline posi to use with your 91's 28 spline axles. Buy it, yank the brakes off then resell to make some money towards a new posi. Posi's don't last forever. They do wear out so buying a used one doesn't mean it's any good.
Old May 28, 2010 | 10:18 PM
AWES0ME1's Avatar
Dang, i meant have a '92 RS 3.1 V6. sorry.
Old May 29, 2010 | 06:21 AM
JamesC's Avatar
Still, as Alky, suggests.
JamesC
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
